Questions below pertain to using Autodesk Inventor 2013:
Can anyone tell me what factor of safety value the Shaft Generator program uses when you run the calculations?
Does the factor of safety value change when you are not using the inventor user material option?
Lastly, when exactly do you know when to use the density option in the calculation properties or not?
I cannot comment on this as it does not seem to be in the help files. Not sure if someone from the QA or development team can reply in here on this topic.
Don
