Inventor General Discussion
Distinguished Mentor
john.retzlaff
Message 11 of 95 (772 Views)
Re: Inventor 2013 SP1
09-21-2012 01:21 PM in reply to: vmcarbonneau
Have you installed SP1?
John Retzlaff
Active Contributor
vmcarbonneau
Message 12 of 95 (769 Views)
09-21-2012 01:24 PM in reply to: john.retzlaff
Just did it, inventor was stable, now it's super unstable
john.retzlaff
Message 13 of 95 (767 Views)
09-21-2012 01:26 PM in reply to: vmcarbonneau
Did you have any errors during the install?
I had a machine have errors about not being able to close Windows Explorer, on this machine I uninstalled, re-booted, and then it was OK.
John Retzlaff
Active Contributor
vmcarbonneau
Message 14 of 95 (762 Views)
09-21-2012 01:34 PM in reply to: john.retzlaff
No error displayed when installing SP1, I will try to do a clean reinstall of Inventor then SP1. Will see if it solves the problem
blair
Message 15 of 95 (755 Views)
09-21-2012 01:53 PM in reply to: john.retzlaff
No problems with install or IV. Inventor actually seems faster.
IV2015 up1 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
john.retzlaff
Message 16 of 95 (755 Views)
09-21-2012 01:54 PM in reply to: blair
Yes, seems a little faster here too.
John Retzlaff
Employee
ChrisMitchell01
Message 17 of 95 (748 Views)
09-21-2012 02:47 PM in reply to: sbixler
Sam,
A 1402 error indicates that you do not have permissions to write to a specific key in the registry. In the error it should tell you where it is trying to write to. You'll need to run regedit, find that key, Rt click go to permissions & ensure that Everyone has Full permission.
If that does not fix it then Set “Everyone” full permission to : HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer
Chris
Chris Mitchell
Inventor Customer Engagement Team
jdits7
Message 18 of 95 (661 Views)
09-24-2012 05:28 AM in reply to: john.retzlaff
Install went fine on 64-bit, don't have any machines that run 32-bit anymore, so not sure there. Inventor seems a little faster, will know more after today.
jdits7
Autodesk Inventor Certified Professional
Blog - http://inventortopix.blogspot.com
Twitter - @InventorTopixJD
*Pro
sbixler
Message 19 of 95 (650 Views)
09-24-2012 05:55 AM in reply to: ChrisMitchell01
I no longer have a record of the specific path that was mentioned, but 2013 is the first version in which this has happened (all the way back to 5.3).  The administrator account that I am using to install the SP is the same one I used for installing 2013 RTM, and therefore the account which created that section of registry.  It works on some machines, or perhaps in some circumstances, not on others.  But I have uninstalled and reinstalled from an udated deployment with no issues on the machines that threw the error.
Active Member
telambert
Message 20 of 95 (567 Views)
09-25-2012 10:28 AM in reply to: sbixler
It looks like that SP1 has been removed from the download area????
I just downloaded and installed it this morning and now the page is missing.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
