Inventor General Discussion
Active Member
Telson.Hadden
Message 11 of 15 (341 Views)
Re: Inventor 2013 - Lag Problem
01-24-2013 04:57 AM in reply to: L.van.Gorsel
Leander.van.Gorsel wrote:
Have you installed the Inv. SP 1.1 + update?
Do you use Vault?
Yes, Service pack and update were installed this week, that's when slowdowns started.
We do use vault, that part of it is pretty good.  I little lag when opening new files due to being stored on the network, but otherwise vault performance is good.
*edited for spelling
Member
mdombovyjohnson
Message 12 of 15 (332 Views)
01-24-2013 05:47 AM in reply to: Telson.Hadden
I would just like to confirm that I am seeing the exact same problem since installing Inventor 2013.
I am currently up to date with service packs and I also use the Vault.
The measurement tool lag sometimes takes over a minute to come back from unresponsiveness. I've also noticed my system RAM seems to take off and never come back down.
-Matt
Valued Mentor
jcneal
Message 13 of 15 (250 Views)
05-30-2013 08:27 AM in reply to: Telson.Hadden
hi
how do you find out "every click in Inventor causes Kaspersky to scan several files."? since i want to show it to IT department. thanks.
Autodesk Inventor Professional 2014
Autodesk Product Design Suite Standard 2013
Microsoft Office 2007 & 2013
Windows 7 64bit
Synergis Adept 2013
Visual Studio Express 2010
Active Member
Telson.Hadden
Message 14 of 15 (226 Views)
05-31-2013 05:24 AM in reply to: jcneal
On the Kaspersky status screen there is a list at the bottom that shows how
many files are scanned.
This list is updated in real-time. It turns out to be a Kaspersky
configuration issue. Inventor folders need to be entered as exceptions.
Also - the major cause of lag turned out to be outdated styles in the
template documents. A "purge" of old styles fixed the issue.
Telson Hadden
Engineering Technician
Beclawat Manufacturing Inc
966-5611 ext 230
Valued Mentor
jcneal
Message 15 of 15 (216 Views)
05-31-2013 09:48 AM in reply to: Telson.Hadden
thanks.
the outdated styles on template  were cleaned.
I can not even go to kaspersky status screen. IT department did a good job...haha
I see kaspersky is running in task manager.
Windows 7 64bit
Synergis Adept 2013
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
