Inventor General Discussion
New Member
thegourou20
Message 1 of 15 (1,028 Views)
Inventor 2013 - Lag Problem
1028 Views, 14 Replies
07-03-2012 06:01 PM
Hi guys,
I have just installed Inventor 2013. I was running Inventor 2012 before and everything was fine.
Now, I am noticing that when I click to edit a dimension for a new part that I have created, it takes a few seconds of delay before I type anything. This is so annoying especially when you do it all the time.
I highly doubt it has anything with the spec of my desktop but anyway it is the following:
Model : HP Z400 Workstation
Processor: Intel(R) Xeon(R) CPU W3670 @ 3.2GHz
RAM: 16GB
Operating System: Windows 7 Professional Service Pack 1 (64bit)
Graphics Card: Nvidia Quadro 4000
Any help would be appreciated.
(N.B: I use a Logitech M500 corded mouse if ever it makes any difference.)
Distinguished Contributor
jrapert
Message 2 of 15 (1,021 Views)
Re: Inventor 2013 - Lag Problem
07-03-2012 07:48 PM in reply to: thegourou20
Not just in dimension editing.
Try switching off components visibility in assembly view in idw, or any general update, constraint application etc. the time-waiting donut just does not want to stop spinning. Very fustrating.
I wish I've never installed 2013. I could do nicely without the (for me) completely useless fancy complicated new material and appearance system.
Julian
IV2013 Product design Suite Premium.
Dell M6400
12 GB RAM
Windows 7 Ultimate 64 Bit
Nvidia Quadro FX3700M 1 GB
Active Member
Telson.Hadden
Message 3 of 15 (791 Views)
01-23-2013 10:17 AM in reply to: jrapert
Similar specs here -
IBM Thinkstation E30
Xeon E31240 3.3Ghz
8 GB Ram
Quaddro 2000
Latest service pack (1.1), Running Kaspersky antivirus
Same issue.
Anyone have ANY input?
Distinguished Mentor
john.retzlaff
Message 4 of 15 (782 Views)
01-23-2013 10:28 AM in reply to: thegourou20
You might try adding an exception to your anti-virus so it excludes scans on the Autodesk folder and subfolders, to see if that makes any difference.
John Retzlaff
karthur1
Message 5 of 15 (776 Views)
01-23-2013 10:41 AM in reply to: thegourou20
Under Tools>Application options.... make sure it is set to either Performance or compatibility.  Software graphics is the slowest.
Are you using custom materials/appearnces?  If you have not modified any you should be good to go with the default stuff that installs.
Active Member
Telson.Hadden
Message 6 of 15 (763 Views)
01-23-2013 11:22 AM in reply to: john.retzlaff
It is set to performance - I've tried everything with no solution.
I have put in a request for exceptions in the Anti-virus, so far no response.
I have noticed that every click in Inventor causes Kaspersky to scan several files.
DarrenP
Message 7 of 15 (755 Views)
01-23-2013 11:34 AM in reply to: Telson.Hadden
try disabling kaspersky and see what happens
Active Member
Telson.Hadden
Message 8 of 15 (736 Views)
01-23-2013 12:56 PM in reply to: DarrenP
I would love to.  We're locked down tighter than fort knox, so I'm not allowed to disable kaspersky in any way, and I can't get any response from IT.
john.retzlaff
Message 9 of 15 (732 Views)
01-23-2013 01:03 PM in reply to: Telson.Hadden
Typical!
John Retzlaff
Active Contributor
L.van.Gorsel
Message 10 of 15 (712 Views)
01-24-2013 04:11 AM in reply to: thegourou20
Have you installed the Inv. SP 1.1 + update?
Do you use Vault?
Green check.png  Please mark as "Accept as Solution" if it answers your question or "Kudos" if you found it useful
Autodesk Inventor 2013 & 2014 Certified Professional
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
