Inventor Forum
Inventor 2013 Drawing Resolution
5 REPLIES 5
panzilte
2325 Views, 5 Replies
We just installed Inventor R2013.  When opening drawings in R2013, the drawing resolution when one is zoomed to the extends of the drawing is very poor.  If one were to open the same drawing in R2011 & R2013 and compare the two then one would see that the resolution is better in R2011.  Is there a setting somewhere in R2013 to make the drawing resolution better?
5 REPLIES 5
JDMather
in reply to: panzilte
Try this Tools>Document Settings
panzilte
in reply to: JDMather
I tried what you had suggested and set the bitmap resolution to 300 dpi (the Max) and the result was the same.  I have attached a screenshot of what the drawing looks like.  If I were to open the same drawing in R2011 everything is legible including the small text in the title block.
okaleja
To me it looks like a graphics issue. Have you tried different graphics settings in Application Options -> Hardware tab ?
Oto,
Oto Kaleja
Software Engineer
panzilte
in reply to: okaleja
That did it thanks
slphantom
Also remember that in 2013 the views have to "regenerate" when you first pull it up. Sometimes depending on the complexity of the assembly and parts it takes a while.
Scott
win 11 64 bit
Nvida GeForce RTX 4000
Inventor Pro 2023
Space Explorer
