Inventor Forum
Inventor 2012 painfully slow
15 REPLIES 15
Message 1 of 16
Anthony
1838 Views, 15 Replies
I am experiencing horrendously slow performance in my Inventor 2012. What I am working on is by no means complex however basic functions like placing constraints just freeze the whole thing up Smiley Mad
Yes I have all the latest service packs installed, drivers, hot fixes etc. etc. and I am running a high spec machine.
Anyone can tell me what on earth is wrong with Inventor ?
Anthony Goodwin ~ Cad Manager/Senior Designer
Autodesk Inventor Professional 2013 SP2 64-Bit Edition
Windows 7 HP Z400, Intel Xeon W3550 3.07GHz
12.0GB RAM, ATI FirePro V4800 (FireGL)
15 REPLIES 15
Message 2 of 16
ampster402
in reply to: Anthony
Anthony wrote:and I am running a high spec machine
what is "high spec" to some....
While you might indeed have a "high spec" machine, it might be bogged down by an onboard graphics card...
But without knowing, who can tell?
System specs?
Message 3 of 16
Anthony
in reply to: ampster402
My machine spec :
HPZ400 Xeon 3.07GHz
12GB Memory
64-bit OS
ATI FirePro V4800 graphics card
My graphics card has been recently upgraded by out IT company.
Message 4 of 16
JDMather
Are you using a 3DConnexion device?
If so, click Calibrate on the 3DConnexion Control Panel.
The CADWhisperer YouTube Channel
Message 5 of 16
phil-mcam
Was it working fine and now is slower?
Is it slower now only after the new video card?
Message 6 of 16
dennymet
Check to make sure you're not using software graphics.
Application Options > Hardware
Ever since I installed my 3dconnexion device, this box gets checked every so often. It's a little annoying but I can live with a couple of quirks, I guess.
Autodesk Product Design Suite 2012 Premium
SolidWorks Premium 2011 SP4.0, Windows 7 Ultimate 64bit SP1
Gigabyte GA-Z68XP-UD5, Intel Core i7-2600k @ 4.66 GHz (103.5 X 45)
Corsair Vengeance 16GB (4 X 4GB) DDR3 1600
EVGA GeForce GTX 580 3072MB 384-bit GDDR5
Patriot Wildfire 120GB SSD, WD VelociRaptor 600GB 10k RPM HDD
Message 7 of 16
blair
You followed all the installation pre-requisites?
1.) Administrative Privileges
2.) UAC turned off, slider to lowest settings
3.) Anti-Virus software disabled
Delta Tau Chi ΔΤΧ
Message 8 of 16
Anthony
in reply to: phil-mcam
Not sure what you mean by 'after the new video card', this video card is the one I've always had when I got my CAD station.
I so have a 3D Connexion devive which is configured for Inventor, I didn't know what this would affect Inventor though.
Message 9 of 16
phil-mcam
You mention a video card upgrade. What did you mean? New hardware? When things go sideways I always ask "what's changed?" It's always a good place to start.
Message 10 of 16
Anthony
Thanks, as far as I know our IT company have made some routine updates via the internet to the video card that came with the machine, I would have thought this would improve performance not the other way round ? Smiley Frustrated
Message 11 of 16
JDMather
Ask Sean Dotson.
Did you try Calibrate?
Did you try unpluging the 3D Connexion device?
Try this - try dragging the sidebar of the feature browser to make it wider.
Is it really slow to resize?
Message 12 of 16
Anthony
in reply to: JDMather
I have clicked the 'calibrate' button on the 3D Connexion control panel but not difference in Inventor.
I haven't unplugged the device but why would I need to do that ? Do you mean unplug then reconnect to see if it sorts out the problem ?
Message 13 of 16
JDMather
I mean unplug and leave it unplugged to see if it makes a difference.
If is doesn't - you have eliminated one possible cause.
Message 14 of 16
Doug_DuPont
Anthony,
Did you figure out your problem? We just upgraded to 2012 and are having the same problem.
We installed SP1, I loaded the lastest video driver.
Douglas DuPont
Inventor 2016 Pro, Vault 2016 Pro
Quadro M4000
Windows 10 64 Bit
Message 15 of 16
Anthony
in reply to: Doug_DuPont
Inventor 2012 is still grinding away even trying to perform basic functions such as bolted connection, assemble etc. not sure why this is but it's becming a real drag, I sincerely hope that Autodesk sort out all these issues in the next release, they should be making sure they have a properly functioning version before releasing it.
Message 16 of 16
blair
Does anything stand out in the Processes when you have the Task-Manager opened. Possibly multi instances of Inventor or something else that's using a lot of resources?
Delta Tau Chi ΔΤΧ
