Inventor Forum
Inventor 2012 file open dialog
5 REPLIES 5
karthur1
593 Views, 5 Replies
In Inventor, when I go to open a file, Inventor remembers the previous fileaname and path (thats good) but I still have to drag the vertical scroll bar to get to the file. If the number of files in the directory is small, then this is a non-issue (you dont have a vert scroll bar), but if it is a large directory, then it becomes a problem.
Watch this video....http://screencast.com/t/YYmm5jeg
In this video, I first open the -19 part, then next I open the -23 part.  I have to pull the scroll bar down to get to this part.
It should remember the filename, path AND highlight the filename in the window.  Here is a thread about the same issue in 2011...http://forums.autodesk.com/t5/Autodesk-Inventor/File-Open-dialog/m-p/2705669/highlight/true#M378013
Will we E-V-E-R get this to function correctly?
This is in Inventor 2012, sp1.  Running on Win7x64.
5 REPLIES 5
MartinBernat
in reply to: karthur1
This seems to be a Win7 issue, I could not reproduce this in Inventor x32 nor x64 on WinXP.
I've found similar issue in our database and I will ask Product Design to prioritize it.
Thanks for reporting!
Martin Bernat
karthur1
in reply to: MartinBernat
Martin,
For what its worth,  When I do a Open>Open from Vault, the last filename that I opened from vault is highlighted in the window (the way that its supposed to work).
Regards
shastu
Does anyone have a solution to this yet?  From my experience it is definately a Windows 7 issue, but I don't know how to fix it.
rush02112
in reply to: shastu
This was working for me up until a couple of weeks ago from a workstation reformat. I vaguely remember there being a registry fix for this issue but can not find what it was. Is this fixed for 2013?
BLHDrafting
Not a fix but handy. I often click on the Name column to do a reverse sort. It gets me to the bottom. Obviously doesn't help with anything in the middle of the list but resizing the wondow can help also.
Brendan Henderson
Web www.blhdrafting.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2016 PDSU SP1 (Build 210), Vault 2016 Professional Update 1 (Build 21.1.4.0)
