Inventor General Discussion
Valued Contributor
Carl_mgfx
Message 1 of 5 (574 Views)
Inventor 2012 does not close
574 Views, 4 Replies
02-09-2012 02:53 AM
Hi all
I have experienced this on multiple computers and I am stumped as to why....
I have install Product Design Suite (either Premium or Ultimate, 32bit or 64bit) on multiple computers.  I set it up to install with the available service packs (off an external HDD) and fill in the required option, serial, product key etc.  For some this work smoothly while on others Inventor 2012 will not shut down after I open it for the first time and then click the "close" cross at the top right.  I have waited for over 10min and nothing, eventually I will "end task" on Inventor to close it.
Am I doing something wrong with these installs, is it the computers?  Has anyone else had this issue? And how was it resolved?
Kind Regards
Carl van Rooyen
Kind Regards
Carl van Rooyen
Application Engineer
Gigabyte Q1542, Win 7 Pro 64Bit, i5 - 3230M, 8 GB Ram
Intel HD Graphics with Nvidia GeForce 640M / 2GB and Optimus
MariaManuela
Message 2 of 5 (564 Views)
Re: Inventor 2012 does not close
02-09-2012 03:33 AM in reply to: Carl_mgfx
Hehe...the problem of the year.
Read this:
http://forums.autodesk.com/t5/Autodesk-Inventor/Inventor-hangs-trying-to-Exit/m-p/3263968#M420991
Maria Manuela Pinho
Application Specialist
Cadtech / Asidek - Autodesk Gold Partner
Autodesk Inventor Professional 2015 | Lenovo W520
New Member
opzmei
Message 3 of 5 (560 Views)
02-09-2012 04:19 AM in reply to: Carl_mgfx
Hi
I am having the same problem with Product Design Suite Ultimate 2012 x64.
Installation is performed from the administrative deployment with integrated service packs for all products.
Inventor 2012 will not shut down after I open it. The "end task" on Inventor to close it is the only solution.
Kind Regards
Andrew
TravisNave
Message 4 of 5 (540 Views)
02-09-2012 09:19 AM in reply to: opzmei
Have you tried disabling the communication center?
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
New Member
opzmei
Message 5 of 5 (535 Views)
02-09-2012 09:55 AM in reply to: Carl_mgfx
Maria Manuela Pinho posted above  the correct link.
The answer is that Inventor Optimization Update requires 15-20 minutes for downloads and does not allow to close the Inventor 2012 window.
The problem is solved, thanks.
Andrew.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
