Inventor Forum
Inventor 2012 does not close
4 REPLIES 4
Carl_mgfx
713 Views, 4 Replies
Hi all
I have experienced this on multiple computers and I am stumped as to why....
I have install Product Design Suite (either Premium or Ultimate, 32bit or 64bit) on multiple computers.  I set it up to install with the available service packs (off an external HDD) and fill in the required option, serial, product key etc.  For some this work smoothly while on others Inventor 2012 will not shut down after I open it for the first time and then click the "close" cross at the top right.  I have waited for over 10min and nothing, eventually I will "end task" on Inventor to close it.
Am I doing something wrong with these installs, is it the computers?  Has anyone else had this issue? And how was it resolved?
Kind Regards
Carl van Rooyen
Kind Regards
Carl van Rooyen
Application Engineer
Inventor 2019, Vault 2019,
HP ZBook 15u G4, Win 10 64Bit (ver 1709), i7-7500U, 16 GB Ram
Intel HD Graphics 620 with AMD Firepro W4190M
4 REPLIES 4
MariaManuela
in reply to: Carl_mgfx
Hehe...the problem of the year.
Read this:
http://forums.autodesk.com/t5/Autodesk-Inventor/Inventor-hangs-trying-to-Exit/m-p/3263968#M420991
Asidek Consultant Specialist
www.asidek.es
Hi
I am having the same problem with Product Design Suite Ultimate 2012 x64.
Installation is performed from the administrative deployment with integrated service packs for all products.
Inventor 2012 will not shut down after I open it. The "end task" on Inventor to close it is the only solution.
Kind Regards
Andrew
TravisNave
Have you tried disabling the communication center?
Autodesk Forums:
Maria Manuela Pinho posted above  the correct link.
The answer is that Inventor Optimization Update requires 15-20 minutes for downloads and does not allow to close the Inventor 2012 window.
The problem is solved, thanks.
Andrew.
