@melmo wrote:
I have tried repairing, reinstalling, and uninstalling inventor but each option fails.
Did you originally install with UAC and anti-virus turned off?
Did you use the Autodesk Clean Uninstall instructions before attempting to do the reinstall (with anti-virus and UAC offf)?
Works fine here in 2012.
Uninstall, then Install using these instructions:
i have same problem
uninstall graphic driver and reinstall new release driver
( cannot update driver , must uninstall and reinstall new release)
then everything OK
I was experiencing the same in Inventor 2011 and running a repair fixed my issue.
Just had this happen to me too. We installed a server at work, and as a result I have a new user account. With the previous comments made I am suspecting it has something to do with the user settings. I will try to repair the installation.
I can go to the save a copy as dialogue where I had always saved the files, and I actually am missing about half of them. It is very bizzare that this would just dissappear like that.
Mike
I head the same problem at a few of Workstations with Inventor 2013 and can't reproduce it. Also the VBA API function SaveAs fails, if .dwg or .dxf should be exported. In the AddIn menue I can manually load the dwg and dxf Translator. After closing the window of the AddIn manager the Translators seem to unload again. Possibly they can't be loaded for some reason. Checked that the .dll files exist in the Inventor/Bin directory.
-Loading default application settings does not help.
-Using an other user account on the Worstation does not help.
-Running a repear with the Autodesk installer does not help.
I have not tried to reinstall jet, because that's really time consuming and should be avoided if possible.
regards,
Andreas
I have the same issue. After running 2013 and then trying to use 2011, 2013 works fine but, 2011 has the following issues:
- File icons show up as a generic inventor icon. It's difficult to tell a .ipt from a .iam, .idw etc.
- Save Copy As does not work.
- Design Assistant does not work.
- iProperties don't work.
All users are power users. All installations were done with UAC turned off and virus software disabled.
When I log-in to any of the workstations as administrator 2011 works fine.
I've tried a repair, a reinstall, a complete uninstall and reinstall - none have worked. As an experiment, I re-imaged one of the computers and started fresh. 2011 worked fine until I ran 2013 once. Then the above functions stopped working on 2011.
I did find a fiix for the iProperties here:
http://forums.autodesk.com/t5/Autodesk-Inventor/PLUGIN-NOT-LOADED/m-p/3268076/highlight/true#M421310
