Inventor 2012 is a poor attempt from Autodesk on an update.
Yes, the update features are "nice", but the amount of crashes and freezes per day (>20) makes in not worth using AT ALL!!!!
Sending reports to Autodesk get the standard automated responises - also not worth filling in.
IF ONLY Autodesk had the feature to DOWNGRADE files to 2011 then at least we would be able to work.
Autodesk, please do not use the WORLD as your BETA TESTERS.
From a VERY DISSAPOINTED (ex?)customer.
Solved by HenkdeSwardt6236. Go to Solution.
Solved by Shiva_Sundaram. Go to Solution.
Wow, its amazing how many other people has since listed their problems.
Autodesk sent us a link to a Hotfix that did resolve the problem. With graphics set on Performance and Capacity/Performance, Enable background updates - Enabled and Memory Saving Mode - Disabled.
Now all seems fine and the repeated 20 crashes per day is a thing of the past.
We get the odd strange crash here and there, but Autodesk is helping us with that as well.
The hotfix is located at:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17235749&linkID=9242019
Thank you Autodesk.
Would that HotFix also include when creating a Base View it crashes as it starts thinking?
The past few days Inv 2012 has been crashed for no apparent reason. Each time it's been almost a different situation, sometimes just while sitting there doing nothing.
If you submitted a crash report, could you please send me the email you used. I can check.
In anycase, if you can apply the hotfix, I would recommend doing so.
Alternately, you can email me your model and/or drawings along with system spec information and steps to reproduce and I can try to see if I can reproduce the crash.
You can reach me at: sundarsATautodeskDOTcom
-Shiva Sundaram
Inventor Development
Autodesk, Inc.
Do you need ALL of the files that were involved? Or just the .idw and .iam files?
You can try doing a pack-n-go which will pull in the required IAM, IPT and IDW files which show the problem. You could try zipping them up and sending them to me. If its too large, let me know and i can try to setup an ftp site for you.
-Shiva Sundaram
Autodesk, Inc.
I'm sorry to hear that you are having issues with Inventor 2012. I would like to have my team investigate these.
Are you providing an email address for these Customer Error Reports?
If so, can you email me this email address? This will allow us to investigate the crashes you are encountering.
My email address is Chuck.Savatsky@Autodesk.com.
