Hi All,
I am currently trying to learn how to use the frame generator. Unfortunately after setting up a simulation and click "simulate" I get the following error " Solver: Failed to Connect to Solver"
Has anyone encountered this issue before?
I did a quick forum search and found some references to an unregistered Kernel 23. i found the folder but no existing exe file.
Any and all help is appreciated
Solved by bmeraz. Go to Solution.
Can you clarify what you mean by simulation? Stress Analysis or Frame Analysis? A screenshot would go a long way! 🙂
If I have to take a guess, I would say try lowering your UAC (User Account Control) found in the below location to the "Never notify" setting.
Control Panel\All Control Panel Items\User Accounts
Hope this helps.
I was attempting to use the frame analysis feature.
It turns out that i was missing some files in a folder called \Robot Kerne 23.0\System
I found a user in my work group with these files and copied pasted them over. Issue is now resolved.
