Inventor Forum
Inventor 2012 - ACME Threads Not Available??
9 REPLIES 9
Message 1 of 10
Panygeric
10553 Views, 9 Replies
Just a basic question I'm seeming to run into - Apparently "ACME"-style threads are not available in Inventor 2012??
9 REPLIES 9
Message 2 of 10
Cadmanto
in reply to: Panygeric
Don't you mean ASME?  If so they coincide with ANSI which are there.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 10
Ray_Feiler
in reply to: Cadmanto
ACME
http://www.mcmaster.com/#about-acme-threads-for-threaded-rods/=me4obt
Product Design & Manufacturing Collection 2024
Sometimes you just need a good old reboot.
Message 4 of 10
Cadmanto
in reply to: Ray_Feiler
Ray,
Fair enough.  I was just checking.
Then the short answer is "No".  You are going to have to create your own thread.
Best Regards,
Scott McFadden
Message 5 of 10
Panygeric
OK - Thanks! Hopefully this is something that will be in the future or just got overlooked?? Man Embarassed It's a fairly common  usage thread type - think of  those feed screws w/ the round spinning turnhandles you find on A LOT of larger shop equipment....
Message 6 of 10
mrattray
That's surprising. I've never had cause to use ACME threads, but I would expect to use them before some of those other odd thread standards Inventor does have.
By the way, ACME threads are standard to use on any sort of jack screw, like the feed screw on an engine lathe.
Mike (not Matt) Rattray
Message 7 of 10
JDMather
For ACME thread type I like actual modeled threads rather than cosmetic representation.
I made an iPart with commonly used sizes.
We were just using this this morning in Dynamic Simulation to demonstrate use of the Screw Joint type.
Message 8 of 10
spec24
Glad to see Autodesk has done nothing regarding implementing ACME threads since this post. 🙄
Message 9 of 10
Mark.Lancaster
in reply to: spec24
@spec24
Not sure what version of Inventor you have but here's a modified Inventor 2018 thread xls file with ACME info in it.
Mark Lancaster
Message 10 of 10
jtylerbc
in reply to: Mark.Lancaster
@Mark.Lancaster, I'll be making use of this as well.  We use ACME threads occasionally, but infrequently enough that I had never gotten around to adding them to the thread spreadsheet.
My thread.xls already has some other customizations, so I'll have to transplant your data into it.  But this will save me some time digging up all the information and typing it in.  Thanks for posting it.
