Inventor General Discussion
Panygeric
Message 1 of 7 (1,252 Views)
Inventor 2012 - ACME Threads Not Available??
1252 Views, 6 Replies
04-19-2013 11:14 AM
Just a basic question I'm seeming to run into - Apparently "ACME"-style threads are not available in Inventor 2012??
Cadmanto
Message 2 of 7 (1,235 Views)
Re: Inventor 2012 - ACME Threads Not Available??
04-19-2013 12:13 PM in reply to: Panygeric
Don't you mean ASME?  If so they coincide with ANSI which are there.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! :smileyvery-happy:
Best Regards,
Scott McFadden
Inventor Professional 2013
(Colossians 3:23-25)
Valued Mentor
RayFeiler
Message 3 of 7 (1,231 Views)
04-19-2013 12:15 PM in reply to: Cadmanto
ACME
http://www.mcmaster.com/#about-acme-threads-for-threaded-rods/=me4obt
Product Design Suite Ultimate 2014 64-Bit
Sometimes you just need a good old reboot.
Cadmanto
Message 4 of 7 (1,226 Views)
04-19-2013 12:26 PM in reply to: RayFeiler
Ray,
Fair enough.  I was just checking.
Then the short answer is "No".  You are going to have to create your own thread.
Best Regards,
Scott McFadden
Panygeric
Message 5 of 7 (1,153 Views)
04-30-2013 04:56 AM in reply to: Cadmanto
OK - Thanks! Hopefully this is something that will be in the future or just got overlooked?? :manembarrassed: It's a fairly common  usage thread type - think of  those feed screws w/ the round spinning turnhandles you find on A LOT of larger shop equipment....
mrattray
Message 6 of 7 (1,144 Views)
04-30-2013 06:24 AM in reply to: Cadmanto
That's surprising. I've never had cause to use ACME threads, but I would expect to use them before some of those other odd thread standards Inventor does have.
By the way, ACME threads are standard to use on any sort of jack screw, like the feed screw on an engine lathe.
Mike (not Matt) Rattray
JDMather
Message 7 of 7 (1,144 Views)
04-30-2013 06:27 AM in reply to: Panygeric
For ACME thread type I like actual modeled threads rather than cosmetic representation.
I made an iPart with commonly used sizes.
We were just using this this morning in Dynamic Simulation to demonstrate use of the Screw Joint type.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
