Where can I find language packs for older Inventor release? My client use Inventor 2011, so I had to downgrade to that version. Only Inventor 2013 language packs are available online.
I'm looking for the English language pack for Inventor 2011.
Thanks!
Hi all,
how can I do to get and download language pack italian for Autodesk Inventor 2011?
Thank's in advance
Max
Hi Max,
Here are the download links for the Italian Language Pack for Inventor 2011:
Best regards,
Hi Camilo,
thanks for your quickly reply but in yours link I found Language pack for AutoCAD Inventor Suite 2011 and doesn't install in my enviroment, I need italian language pack for Autodesk Inventor 2011 standard.
Regards
Max
Our apologies Max as we actually do not offer a Language Pack for Inventor 2011.
As such, please utilize the following 30 day direct download links:
Inventor 2011 (ITIALIAN) 32 BIT: PART1, PART2
Inventor 2011 (ITALIAN) 64 BIT: PART1, PART2
Here to help if additional clarification is needed, otherwise please accept as a solution so that others can benefit from this information.
I Philip,
but I need Autodesk Inventor 2011 Standard in ITALIAN language, no in French, how can I do to get it?
Chers
Max
I'm soo sorry about that / the previous response has just been updated with the correct links 🙂
Philip,
this links are Autodesk Inventor Professional, I need Autodesk Inventor standard 2011 italian, I have a serial number with product key 208C1, how can I do to get this download:
Please help me
Cheers
Max
Shucks! Upon further research it doesn't look there are any versions of standard Inventor outside of the English language.
My sincere apologies for the misinformation earlier and dragging this one on.
anjulon
DId you read the posting above yours:
It says (back in 2013): Upon further research it doesn't look there are any versions of standard Inventor outside of the English language.
Mark Lancaster
& Autodesk Services MarketPlace Provider
Hi! I don't believe Inventor 2011 was LP enabled. You will need to install the full version of a given language. Do you have access to more recent releases like 2018 or 2019?
Many thanks!
