I get a problem when i insert a new logo in a title block. it looks perfect. But at print preview, the ratio of the image get messed up and on print, the image is gone. I tryed with other BMP's and other templates. all the same.
whats wrong? Or whats diffrent from older Inventor releases?
hope you know.
Henrik Graversen
Solved by Martin_Goodland. Go to Solution.
Hello
There is a Hot fix for this on Autodesk's website.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15192521&linkID=9242019
Regards
Martin
