I have succesfully installed Autodesk Inventor 2011 (Student License) on my Windows 7 (64-bit) operating system without any errors.
I can open Inventor 2011, but when I try to open a new or existing file, Inventor suddenly closes and the 'Autodesk Inventor Error Report'-window opens, giving the following error:
Error: Unhandled Exception
When I go to my project folders and try to open any inventor file, the following message appears:
"Inventor.exe needs to register with he operating system and the following programs (Explorer) are running and may
prevent registration from succesfully completing. Autodesk recommends terminating the offending processes to ensure
proper registration. Terminate these processes before continuing with the registration?"
If i cick 'Yes', the problem remains.
I've tried reinstalling, following the intructions carefully (installed as adminstrator), without succes. I installed both service packs. I keep having the same problems, whlle in the past, it has been working perfectly, but I lost it because of hardware problems, which are now resolved.
What can be the problem here? What am I doing wrong here?
Technical Info:
OS: Windows 7 64-bit
Processor: Intel(R) Core(TM) i5 CPU M430 @ 2.27GHz
4,00 GB RAM
ATI Mobility Radeon HD 5650
Greetings,
Dennis
Try right-clicking on the desktop icon and choose "Run as Administrator". Also, I usually set my User Account Control settings to "Never Notify". It's always a good idea to have administrative rights, when possible.
Also, it is recommended that you disable any antivirus or firewall software when installing. Sometimes they will prevent Inventor from editing the registry correctly.
Have you tried doing a repair? In the Add/Remove Programs, click change on Inv 2011, choose Repair.
I'm also assuming you've tried rebooting the computer after you did the installation?
When you said that you uninstalled before, did you just go to Add/Remove Programs and Uninstall or did you do a "Clean Uninstall"? In cases like this, Autodesk recommends that you do a "clean uninstall" which removes any trace of all Autodesk software, including cleaning out the registry.
There is an automated way and a manual way of doing this. See the link below for detailed instructions.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?id=14893355&linkID=9242018&siteID=123112
And, as before, make sure you have admin rights and have turned off any antivirus software before doing the new install.
Do the clean un-install as stated. Make sure your .NET is version 4.0, log in as the Administrator, set the UAC slider to it's lowest setting and re-install Inventor. Depending on the Anti-Virus software you have, you may need to stop it's Services while you install Inventor.
I did all the steps that are listed above, but I keep having the same issues. I ran everything as administrator, disabled the antivirus and did the clean uninstall and installed it again, rebooted and ran inventor.exe as administrator, but the problem remains.
1 difference: When I try to open inventor by opening an existing .prt-file, the following message doesn't appear anymore:
Now it wil open inventor, but immedeatly close it again without displaying the part.
A good chance something is causing the Windows Registry not to update. Try installing the Service Packs, but I think you have other issues with your machine.
Trying having an IT person run ComboFix and check for any Malware or Virus's.
Are you opening Inventor first and then opening the part from within Inventor?
You may want to post this in the Installation/Registration user forum.
