Hello
I reinstalled IV2010Sim on the new PC and when i started doing simulations it started crashing right after the simulation finished. I looked at the dmp file, couldn't make much sense of it besides FEAManager being the culprit.
Any ideas?
System is:
Win7 Pro x64
CPU i7 2600k
GPU Nvidia GTX590
RAM 32GB DDR 1300MHz
SSD Crucial m4
Loading Dump File [C:\Users\User\Desktop\Inventor120118135110.dmp] User Mini Dump File: Only registers, stack and portions of memory are available Symbol search path is: SRV*C:\Symbols*http://msdl.microsoft.com/download/symbols Executable search path is: Windows 7 Version 7601 (Service Pack 1) MP (8 procs) Free x64 Product: WinNt, suite: SingleUserTS Machine Name: Debug session time: Wed Jan 18 13:51:10.000 2012 (UTC + 2:00) System Uptime: not available Process Uptime: 0 days 0:16:46.000 ................................................................ ................................................................ ................................................................ ................................................................ ................................................................ ................................................................ .................................................... This dump file has an exception of interest stored in it. The stored exception information can be accessed via .ecxr. (1380.438): Unknown exception - code c000000d (first/second chance not available) ntdll!NtGetContextThread+0xa: 00000000`77661fea c3 ret 0:028> g ^ No runnable debuggees error in 'g' 0:028> g ^ No runnable debuggees error in 'g' 0:028> !analyze -v ******************************************************************************* * * * Exception Analysis * * * ******************************************************************************* *** ERROR: Symbol file could not be found. Defaulted to export symbols for FEAManager.dll - *** ERROR: Symbol file could not be found. Defaulted to export symbols for FEA_Logic.dll - *** ERROR: Symbol file could not be found. Defaulted to export symbols for FWx_Master_Events_Management.dll - *** ERROR: Symbol file could not be found. Defaulted to export symbols for RxAppDocView.dll - *** ERROR: Symbol file could not be found. Defaulted to export symbols for rse.dll - *** ERROR: Symbol file could not be found. Defaulted to export symbols for fw.dll - *** ERROR: Symbol file could not be found. Defaulted to export symbols for RxAssembly.dll - *** ERROR: Symbol file could not be found. Defaulted to export symbols for RxUtil.dll - *** ERROR: Symbol file could not be found. Defaulted to export symbols for FWx_Change_Definition.dll - *** ERROR: Symbol file could not be found. Defaulted to export symbols for FWx_Business_Logic.dll - *** ERROR: Module load completed but symbols could not be loaded for Inventor.exe *** ERROR: Symbol file could not be found. Defaulted to export symbols for adlmint.dll - *** ERROR: Symbol file could not be found. Defaulted to export symbols for nvwgf2umx.dll - *** ERROR: Symbol file could not be found. Defaulted to export symbols for vbc64.dll - Failed to load data access DLL, 0x80004005 Verify that 1) you have a recent build of the debugger (6.2.14 or newer) 2) the file mscordacwks.dll that matches your version of mscorwks.dll is in the version directory 3) or, if you are debugging a dump file, verify that the file mscordacwks_<arch>_<arch>_<version>.dll is on your symbol path. 4) you are debugging on the same architecture as the dump file. For example, an IA64 dump file must be debugged on an IA64 machine. You can also run the debugger command .cordll to control the debugger's load of mscordacwks.dll. .cordll -ve -u -l will do a verbose reload. If that succeeds, the SOS command should work on retry. If you are debugging a minidump, you need to make sure that your executable path is pointing to mscorwks.dll as well. Failed to load data access DLL, 0x80004005 Verify that 1) you have a recent build of the debugger (6.2.14 or newer) 2) the file mscordacwks.dll that matches your version of mscorwks.dll is in the version directory 3) or, if you are debugging a dump file, verify that the file mscordacwks_<arch>_<arch>_<version>.dll is on your symbol path. 4) you are debugging on the same architecture as the dump file. For example, an IA64 dump file must be debugged on an IA64 machine. You can also run the debugger command .cordll to control the debugger's load of mscordacwks.dll. .cordll -ve -u -l will do a verbose reload. If that succeeds, the SOS command should work on retry. If you are debugging a minidump, you need to make sure that your executable path is pointing to mscorwks.dll as well. GetPageUrlData failed, server returned HTTP status 404 URL requested: http://watson.microsoft.com/StageOne/Inventor_exe/14_4_0_28400/4e040628/FEAManager_dll/14_4_0_28400/... FAULTING_IP: FEAManager!DllUnregisterServer+a3974 00000000`33985594 498b6c2440 mov rbp,qword ptr [r12+40h] EXCEPTION_RECORD: ffffffffffffffff -- (.exr 0xffffffffffffffff) ExceptionAddress: 0000000033985594 (FEAManager!DllUnregisterServer+0x00000000000a3974) ExceptionCode: c000000d ExceptionFlags: 00000000 NumberParameters: 0 PROCESS_NAME: Inventor.exe ERROR_CODE: (NTSTATUS) 0xc000000d - An invalid parameter was passed to a service or function. EXCEPTION_CODE: (NTSTATUS) 0xc000000d - An invalid parameter was passed to a service or function. MOD_LIST: <ANALYSIS/> MANAGED_STACK: !dumpstack -EE Failed to load data access DLL, 0x80004005 Verify that 1) you have a recent build of the debugger (6.2.14 or newer) 2) the file mscordacwks.dll that matches your version of mscorwks.dll is in the version directory 3) or, if you are debugging a dump file, verify that the file mscordacwks_<arch>_<arch>_<version>.dll is on your symbol path. 4) you are debugging on the same architecture as the dump file. For example, an IA64 dump file must be debugged on an IA64 machine. You can also run the debugger command .cordll to control the debugger's load of mscordacwks.dll. .cordll -ve -u -l will do a verbose reload. If that succeeds, the SOS command should work on retry. If you are debugging a minidump, you need to make sure that your executable path is pointing to mscorwks.dll as well. IP_ON_HEAP: 00000000b10000b1 The fault address in not in any loaded module, please check your build's rebase log at <releasedir>\bin\build_logs\timebuild\ntrebase.log for module which may contain the address if it were loaded. IP_IN_VM_BLOCK: b10000b1 FRAME_ONE_INVALID: 1 LAST_CONTROL_TRANSFER: from 0000000033985594 to 0000000072ddb1e5 FAULTING_THREAD: 0000000000000438 DEFAULT_BUCKET_ID: STATUS_INVALID_PARAMETER PRIMARY_PROBLEM_CLASS: STATUS_INVALID_PARAMETER BUGCHECK_STR: APPLICATION_FAULT_STATUS_INVALID_PARAMETER STACK_TEXT: 00000000`3aefdeb0 00000000`33985594 : 00000000`339ad508 00000000`04aa3d80 00000000`04d38740 00000000`047472e8 : msvcr80!_invalid_parameter_noinfo+0x55 [f:\dd\vctools\crt_bld\self_64_amd64\crt\src\invarg.c @ 99] 00000000`3aefe470 00000000`33987f85 : 00000000`00000000 00000000`04aa3d80 00000000`04aa3d80 00000000`0474ba10 : FEAManager!DllUnregisterServer+0xa3974 00000000`3aefe860 00000000`33938b38 : 00000000`04aa3d80 00000000`04aa3d80 00000000`047484b0 00000000`04aa3d80 : FEAManager!DllUnregisterServer+0xa6365 00000000`3aefe950 00000000`33908eda : 00000000`2aa2bf08 00000000`04aa3d80 00000000`04749370 00000000`04749370 : FEAManager!DllUnregisterServer+0x56f18 00000000`3aefebf0 00000000`3391c286 : 00000000`04aa3d80 00000000`04aa3d80 00000000`0474bd40 00000000`04aa3d80 : FEAManager!DllUnregisterServer+0x272ba 00000000`3aefeca0 00000000`3391fa69 : 00000000`04aa3d80 00000000`00000004 00000000`0000ffff 00000000`04754340 : FEAManager!DllUnregisterServer+0x3a666 00000000`3aefed70 000007fe`fedf23d5 : 00000000`04a87fd8 00000000`0000ffff 00000000`00000000 00000000`00000004 : FEAManager!DllUnregisterServer+0x3de49 00000000`3aefef00 000007fe`fede69b2 : 00000000`3aeff330 00000000`2ade1630 00000000`00000030 00000000`09bff88e : rpcrt4!Invoke+0x65 00000000`3aefef60 000007fe`ff06376f : 00000000`2ade1310 00000000`00000001 000007fe`ff0771e0 000007fe`ff082fb0 : rpcrt4!NdrStubCall2+0x32a 00000000`3aeff580 000007fe`fed010c4 : 000007fe`00000001 00000000`2aa2c440 00000000`0418cbd0 000007fe`ff060883 : ole32!CStdStubBuffer_Invoke+0x9c 00000000`3aeff5b0 000007fe`ff060ccd : 00000000`00000000 00000000`00000000 ffffffff`d5299de7 00000000`00000000 : oleaut32!CUnivStubWrapper::Invoke+0xe4 00000000`3aeff600 000007fe`ff060c43 : 00000000`2ec910f0 00000000`2aa2c524 00000000`0998e560 00000000`339a2968 : ole32!SyncStubInvoke+0x5d 00000000`3aeff670 000007fe`fef1a4f0 : 00000000`2ec910f0 00000000`2adce6f0 00000000`2ec910f0 00000000`00000000 : ole32!StubInvoke+0xdb 00000000`3aeff720 000007fe`ff0614d6 : 00000000`00000000 00000000`00000010 00000000`2aa2c440 00000000`0418dd60 : ole32!CCtxComChnl::ContextInvoke+0x190 00000000`3aeff8b0 000007fe`ff06122b : 00000000`d0908070 00000000`2adce6f0 00000000`09fca3e0 00000000`29f82ca0 : ole32!AppInvoke+0xc2 00000000`3aeff920 000007fe`ff063542 : 00000000`2ec91060 00000000`00000000 00000000`00000000 00000000`00000000 : ole32!ComInvokeWithLockAndIPID+0x52b 00000000`3aeffab0 000007fe`fef2d42d : 00000000`0418dd60 106eab5d`00001269 00000000`0418c5d0 00000000`2ec91060 : ole32!ComInvoke+0xae 00000000`3aeffae0 000007fe`fef00106 : 00000000`2ab494c0 00000000`00000000 00000000`00000001 00000000`00001440 : ole32!ThreadDispatch+0x29 00000000`3aeffb10 000007fe`fef00182 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : ole32!CRpcThread::WorkerLoop+0x1e 00000000`3aeffb50 00000000`773b652d : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : ole32!CRpcThreadCache::RpcWorkerThreadEntry+0x1a 00000000`3aeffb80 00000000`7763c521 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : kernel32!BaseThreadInitThunk+0xd 00000000`3aeffbb0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : ntdll!RtlUserThreadStart+0x1d STACK_COMMAND: .cxr 0000000000000000 ; kb ; ~28s; .ecxr ; kb FOLLOWUP_IP: FEAManager!DllUnregisterServer+a3974 00000000`33985594 498b6c2440 mov rbp,qword ptr [r12+40h] SYMBOL_STACK_INDEX: 1 SYMBOL_NAME: feamanager!DllUnregisterServer+a3974 FOLLOWUP_NAME: MachineOwner MODULE_NAME: FEAManager IMAGE_NAME: FEAManager.dll DEBUG_FLR_IMAGE_TIMESTAMP: 4e03f7fe FAILURE_BUCKET_ID: STATUS_INVALID_PARAMETER_c000000d_FEAManager.dll!DllUnregisterServer BUCKET_ID: X64_APPLICATION_FAULT_STATUS_INVALID_PARAMETER_feamanager!DllUnregisterServer+a3974 WATSON_STAGEONE_URL: http://watson.microsoft.com/StageOne/Inventor_exe/14_4_0_28400/4e040628/FEAManager_dll/14_4_0_28400/... Followup: MachineOwner --------- 0:028> lmvm FEAManager start end module name 00000000`338a0000 00000000`33a14000 FEAManager (export symbols) FEAManager.dll Loaded symbol image file: FEAManager.dll Mapped memory image file: C:\Program Files\Autodesk\Inventor 2010\bin\FEAManager.dll Image path: C:\Program Files\Autodesk\Inventor 2010\bin\FEAManager.dll Image name: FEAManager.dll Timestamp: Fri Jun 24 05:35:42 2011 (4E03F7FE) CheckSum: 0017AF63 ImageSize: 00174000 File version: 14.4.0.28400 Product version: 1.0.0.1 File flags: 0 (Mask 3F) File OS: 40004 NT Win32 File type: 2.0 Dll File date: 00000000.00000000 Translations: 0409.04b0 CompanyName: Autodesk, Inc. ProductName: Autodesk, Inc. FEAManager InternalName: FEAManager OriginalFilename: FEAManager.dll ProductVersion: Autodesk Inventor 2010 FileVersion: 14, 4, 0000, 28400 PrivateBuild: Build: 284, Release: 2010 SP4 - Date: Thu 06/23/2011 SpecialBuild: Build: 284, Release: 2010 SP4 - Date: Thu 06/23/2011 FileDescription: FEAManager LegalCopyright: Copyright © 1996–2009 Autodesk, Inc. LegalTrademarks: Copyright © 1996–2009 Autodesk, Inc. Comments: Copyright © 1996–2009 Autodesk, Inc.
Solved by henderh. Go to Solution.
It crashes every time in static analysis, modal analysis works (excluding the mesher, see below)
Additionally, the mesher doesn't work when the average element size is below 1 (doesn't start "loading").
I did the other variant (registry), didn't change anything.
Thanks for providing the additional information anriil. I've sent the data on to Development for further investigation.
[Edit: Development wants to know what you see if you just do a "Mesh View" using the default mesh settings]
A few more questions and comments from Development to dig deeper into the issue:
1) Are you using comma as the decimal separator? Can you provide screenshots of the meshing dialog?
2) From the log file, you've enabled separate stress across contacts. Can you disable the option and check if solving succeeds?
3) The FEAComputeserver.log is incomplete. Please create a new part, save it as cube.ipt (something else would work, but we want a name for the model). Then do the workflow. This would enable use to get a better log file.
Thanks! -Hugh
Hi Anriil,
Thank you for posting the part and all the attachments. As you have shown, somehow the mesh settings have become zero, causing the problem.
Would it be possible to do one more test?
1) Change the O/S regional settings to not use comma as the decimal separator (e.g. English, United States)
2) Restart Inventor & open the cube part
3) Create a new simulation and use the Mesh View command
Our apologies for the inconvenience.
Best regards, -Hugh
