Inventor Forum
Inventor 2008 and Technical Illustrations
17 REPLIES 17
Message 1 of 18
1060 Views, 17 Replies
Hi there, does anyone have information on how useful inventor 2008 is when it comes to making a technical illustration? and let me also know if there is any short coming in that aspect. This is because I am looking for a Dissertation topic and I want to base it on Technical illustrations using Autodesk inventor. Thank you
17 REPLIES 17
Message 2 of 18
JDMather
At what level is this dissertation intended?
I think you are going to be hardpressed to fine enough information on Inventor for Technical Illustrations.
Message 3 of 18
Josh_Petitt
I was thinking the same thing. If this is a dissertation for a 1 semester CAD course then it might be a good topic. If it is a MS or PhD dissertation, then there is not enough info, or opportunities for research.
Message 4 of 18
There were a couple of classes at AU 2007 that might help you in your
research. Send me an email direct and I will pass on the email
addresses of the authors.
Hal Gwin
Mechanical Designer
Caliper LifeSciences
R2008 Pro SP2 D3D
XP Pro SP2
Dell Precision 650
Dual 2.66 GHz Xeon
3 GB DDR
Quadro FX 3000
nVidia 6.14.11.6262 w/registry update
Dell UltraSharp 24" Widescreen LCD
Message 5 of 18
Thanks for the reply....The dissertation is for my Bsc in CAD. the dissertation is meant to try and find a solution or an alternative method to a CAD problem. so i think i might be able to work with inventor in this case. Any more information on this is highly welcome. Thanks
Message 6 of 18
thanks for the reply. Can you please let me know how to get your email adress. Thanks
Message 7 of 18
Josh_Petitt
by a Technical Illustration, do you mean a drawing as part of a printed manual? Inventor is very good at producing technical illustrations. I think the biggest problem that has been addressed on this forum is integration with word processing programs. The problem there is having an easily updateable document that stays in sync with the design, has appropriate printing resolution, and can be labeled to make a list of illustrations for the document table of contents.
In the "real" world, I don't know how much this is actually done compared to design documentation. We don't do any documentation outside Inventor, but for our needs there is relatively little writing compared to drawing and annotation.
Message 8 of 18
Thank you. I will look into the suggestion you put down. I am talking about an illustration such as the attached and looking at comparing methodologies on how best to create such within Inventor, a 2D software and an illustration package.
Message 9 of 18
Josh_Petitt
ah, well Inventor cannot produce that image directly, but with a combination of Inventor Studio and Photoshop, you could make that image fairly easy (given that you already had a complete model of the motor 😉 )
Message 10 of 18
Should appear in the "from". It is hal.gwin@caliperls.com
Hal Gwin
Mechanical Designer
R2008 Pro SP2 D3D
XP Pro SP2
Dell Precision 650
Dual 2.66 GHz Xeon
3 GB DDR
Quadro FX 3000
Message 11 of 18
thank you for your reply. Can you please give me a few examples of such word processing programs. Thank you
Message 12 of 18
Josh_Petitt
do a search on this site for "manuals" or similar topics. Microsoft Word and Adobe Illustrator are two that come to mind, but there might be more.
Message 13 of 18
thanks yet again for your reply. I have got one more question though. The question is, has there been a solution to this problem, and if there hasn't, have you got any suggestions as to how best to overcome it. Thanks
Message 14 of 18
Josh_Petitt
this isn't my dissertation 😉 search this NG and you will find many variations on solutions.
Message 15 of 18
dan.mckibbon
one drawback I have found is the lack of cgm output. I use NX6 at work and have the ability to directly output to cgm files and then use them in Adobe Illustrator.
Message 16 of 18
sam_m
in reply to: dan.mckibbon
you do realise this topic was from 4 years ago???  I'm guessing (and hoping) the dissertation was finished long ago...
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
Message 17 of 18
great thread. very informative. i enjoy reading it.
[url=http://jimfloor.net/team-ina-provides-leverage]Leverage[/url]
Tags (1)
Message 18 of 18
dan.mckibbon
in reply to: sam_m
I am using Inventor 2011 and have not yet found a way to export or save to CGM file format. I supose Autodesk has not made this capability available in the last four years.
