You need a VizStream enabled server in order to stream zgl files over the
web or a Streamline or RealityWave account. You can't simply install a
viewer, post a zgl file to your html folder and have a web viewer... well
you can... sort of.... but then visitors could download your zgl file. The
idea is to have the model streamed to the viewer without actually
downloading a file. This gives you control over who sees what and when.
Dave
"Sean Dotson"
wrote in message
news:3A35C715A43520DB639CB5A49C4FE398@in.WebX.maYIadrTaRb...
> the AMP are streamline based but the ZGL and XGL have free viewers out
> there...(see post above for one)
> Sean Dotson, PE
> http://www.sdotson.com
> remove all #s from email
> "David Radlin" wrote in message
> news:82E9264BD72BB4753712077BA27D6A5C@in.WebX.maYIadrTaRb...
> > ... which are not much use unless you have a Streamline or similar
> > RealityWave VizStream based account. Autodesk wants you to go the
> > Streamline route.
> > I guess I don't blame them but I'd like to see more options available to
> me
> > in this area.
> > If Dassault is using OpenHSF then that is reason for Autodesk not to
> (VBG).
> > Dave
> > "Sean Dotson" wrote in message
> > news:7DD3E3296CC4546CFBD0A13AD1D7E596@in.WebX.maYIadrTaRb...
> > > FYI: IV has their own version of this in the form of XGL and ZGL
> > files..as
> > > well as AMP (Streamline assembly packages)
> > > (couldn't let the other guys get the last word)
> > > Sean Dotson, PE
> > > "Bob MacGillivray" wrote in message
> > > news:f11fdfc.-1@WebX.maYIadrTaRb...
> > > > http://go.cadwire.net/?3270,3,101.65,572
