Every file shows as corrupt files. Need help. trying to install Autodesk inventor pro. 2011 ???
Hi tcrider1,
Thanks for your report but in order to understand your problem more clearly, need more information from your, for example, do you use Autodesk Inventor Professional 2011 EF or ISO to install ? Does it have error message about "Every file shows as corrupt files ? Can you attach a screenshot for it ? You can refer to the installation tutorial from here: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17546373&linkID=16831209 .
Kevin Li
SQA Engineer
Autodesk, Inc.
