Open a command prompt.
2. Navigate to the %SYSTEMROOT%\Microsoft.Net\Framework\v2.0.50727 directory.
3. Type "aspnet_regiis.exe -i" and press Enter.
4. After this is complete, perform an IISRESET from a command prompt and restart the pre-checks.
This does it for most of the times.
Keep in mind: Only when you have IIS installed is when you won't have the option to install AWS.
David
This did solve all errors and warnings we had, (installation still failed Vault 2012). Thanks this is key information that really helped. Will keep on till we have a successful install.
Regards Blair I,
Senior Design Draughtsman/IT CAD support/ SouthernDHB NZ
