Inventor Forum
Install local help on different disc
1 REPLY 1
high.lea
244 Views, 1 Reply
Does anyone know if it possible to install the local help sytem in a different place to the Inventor install disc.
I have Inventor on my c drive which is an SSD and nearly full. I put the local help files on the d drive, but Inventor cannot see them.
Thanks Colin
1 REPLY 1
Yong.Jing
in reply to: high.lea
From Help installation instruction, you could below information: Additional Standalone Installation information If you change the default install location (which is C:\Program Files\Autodesk\Inventor 2014\Local Help), you must create a registry entry with the full path where the Local Help is located. The registry entry must be created in the following location with the following values: Path: HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Inventor\RegistryVersion18.0 Key: Local Help String: [Path to the Local Help] Example: C:\MyLocalHelp\ http://download.autodesk.com/us/support/files/inventor_2014_online_help/help_install_instructions_in...
Yong Jing
Product Support Senior Specialist
Technical Support, CSS, GPS
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
如果我的回帖解决了您的问题,请点击 "接受为解决方案" 按钮. 这可以帮助其他人更快的找到解决方案!
