Is there any way to insert a generic table into an assembly file. I don't want to create an iAssembly or use the data to configure the component in any way. I would just like to be able to maintain some design related information within the assembly file, similar to the tables that you can create in an idw. A table just like the iAssembly table would be fine, minus the iAssembly part or any sense of configuration.
Steve
I don't think it's possible to have a table floating like in a drawing file. However it is possible to insert an excel table into an assembly file using engineers notebook.
right-click the assembly > create note > insert object > excel spreadsheet
This will embed a table like this one ^ inside the assembly file
another possible solution
I was hoping to be able access the values on this table through iLogic so it would need to be more than just merely cosmetic.
Steve
Steve
Have you given us all the details now? Be specific with exactly what you are trying to do..
I don't like being spoon fed information..
I think what you really want is to use the "parameters" dialog (the fx button) in Inventor.. That way you can reference that in dimensions,etc...
