Inventor Forum
Indexed Rotation
5 REPLIES 5
ericrbunn
398 Views, 5 Replies
Indexed Rotation
I want to constrain two parts to rotate about the same axis.  One fixed and one to rotate by a specified indexed amount.  For example to rotate in 60 degree increments.  This would make the part rotate around a center 360 degrees but in 60 degree increments only.
5 REPLIES 5
MariaManuela
in reply to: ericrbunn
Drive Constraint tool????
Asidek Consultant Specialist
www.asidek.es
RyanBotha
in reply to: MariaManuela
That might work actually. Set the increment to 60deg. You wont be able to drag the component to show movement though.
ericrbunn
in reply to: RyanBotha
If possible I would like to turn it freely by this increment.
ericrbunn
What type of constaint is being driven by your screen shot.  I have two parts that rotate around a common axis.  What type of constraint do I need?
MariaManuela
Angle constraint...between two planes passing through the both axis.
www.asidek.es
