I have some parts with varies User Parameters that allow cusomization of part features. With numeric user paremeters we can check the export parameter box and then, in the description of the part we can refrence that parameter. For instance the description could be: =Width <Width>, Height <Height>, etc. Where it would desplay as Discription: width 22in, height 12".
We also have text User parameters. Is there a way to add these parameters to the description as well? They do not have the option of checking the export parameter box in the parameters table.
Matt
Firgured it out. you can write an iLogic rule as follows to add a custom field on the custom tab and insert the value of the text parameter.
iProperties.Value("Custom", "Drive Location")= Drive
