I made a table in the file and also split the part into 2 solids.
In the drawing, when i choose the first table mamber it shows both. when i choose to show the active member it shows the first member only (as i want).
It didn't happen before i split the part.
My zip program doesn't know to include only the subfolder with the generated table files, only the whole path. i hope you will manage to generate the files, if not-i will add them with the whole path
One of the things you’re seeing is the results of making the drawing view from the parent file (the one with the table). The idw/drawing file will follow whatever is the active member is in the parent file. If you need or want to have just a child view (like #602 VAS-10!5-BH-01=1.04-01) you will need to recreate the view and select the child in the Model State tab and select the iPart Member in place of Active Factory Member.
