Inventor Forum
In a drawing, table members don't show
1 REPLY 1
Karol-Or
311 Views, 1 Reply
I made a table in the file and also split the part into 2 solids.
In the drawing, when i choose the first table mamber it shows both. when i choose to show the active member it shows the first member only (as i want).
It didn't happen before i split the part.
My zip program doesn't know to include only the subfolder with the generated table files, only the whole path. i hope you will manage to generate the files, if not-i will add them with the whole path
1 REPLY 1
mercerc
in reply to: Karol-Or
            One of the things you’re seeing is the results of making the drawing view from the parent file (the one with the table). The idw/drawing file will follow whatever is the active member is in the parent file. If you need or want to have just a child view (like #602 VAS-10!5-BH-01=1.04-01) you will need to recreate the view and select the child in the Model State tab and select the iPart Member in place of Active Factory Member.
Charlie M
Inventor Product Support Specialist
