I am doing the CAD portion of a VEX robotics competion. If there is a way to import the metal Vex parts from somewhere please give me the link. I'm not looking for the plastic parts I saw in "VEX Assembly."
I need the metal parts seen here: http://www.vexrobotics.com/vex/products/accessories
Hopefully I didn't post a question someone has already asked. I'm sorry if I did.
At the bottom of the pages once you click into those things there is a link to the step files, which you can import with Inventor.
http://content.vexrobotics.com/cad/STEP/Vex-Hardware-and-Metal-Kit-STEP-10182007.zip
Do a normal Inventor open and change you file type to STEP... Just keep in mind these imported files will be considered as a "dumb" solid.
Mark Lancaster
& Autodesk Services MarketPlace Provider
I´m looking for this component: High Strength 60-Tooth Gear-With High Strength Square Gear
Someone could help me please?
@petergreco15 wrote:I am doing the CAD portion of a VEX robotics competion. If there is a way to import the metal Vex parts from somewhere please give me the link. I'm not looking for the plastic parts I saw in "VEX Assembly."
Can I get a pneumatics kit for Inventor because there is not one on the kit of parts I have at the moment
Did you try here?
https://www.autodesk.com/education/competitions-and-events/vex/recommended-software#Kit-of-parts
Or here?
http://www.mediafire.com/file/nfhyn9jk3vhc1a1/VEX+Parts+Library+2016.zip
Or ask your teacher to help you model them up?
There also seem to be multiple pneumatics kits so you need to be specific about which one you want..
