Inventor Forum
Importing STL files
16 REPLIES 16
Message 1 of 17
24541 Views, 16 Replies
Importing STL files
Quick question - is Inventor compatible with STL files (probably not as I haven't succeeded getting them in)? I've got an object scanned and need this scan data as template to rebuild the object in Inventor. If STL files can't be imported, are there any other ways how to get point clouds or meshes into Inventor (or is it just impossible)?
Tags (3)
16 REPLIES 16
Message 2 of 17
JDMather
If you search here you should find an stl object enabler.
The import is for reference - it is not geometry.
http://modthemachine.typepad.com/my_weblog/2009/07/working-with-stl-and-obj-files.html
Message 3 of 17
KevinLi-Autodesk
Hi AnnaScura,
Appreciate your report !
We had already noticed this requirement and will implement STL import translator enhancement in furture release, but this is not available in Inventor 2012 and hopefully it will be available in next release.
Kevin Li
SQA Engineer
Autodesk, Inc.
Kevin-Hongyuan Li
Software Quality Assurance Engineer
Design, Lifecycle and Simulation Product Group
Direct: +86 21 2039 6025
Email: Hongyuan.Li@autodesk.com
Autodesk, Inc.
NO. 130, Lane 91, E Shan Rd
Building 12, Floor 6,
Shanghai 200127, PRC
www.autodesk.com
Message 4 of 17
DEVR3856
There is now a plug-in from CodeDog that will import .Stl (binary) files into AutoCAD as a 3D Mesh, it also imports .Ply, .Off and .Obj files including Materials/Textures from .mtl files.
http://www.CodeDog.com.au
Tags (5)
Message 5 of 17
leej0nes
in reply to: DEVR3856
Do you know of anything similar for Macs?
Lee.
Message 6 of 17
JDMather
in reply to: leej0nes
Autodesk Fusion 360  and it is free for most users.
Message 7 of 17
leej0nes
in reply to: JDMather
Great, thank you!!! 🙂
Message 8 of 17
leej0nes
It only appears to support export and not import 😞
Message 9 of 17
JDMather
I didn't realize there was any difference between the Windows version and the Mac version.
Opens just fine on my Windows install.
I thought most Fusion 360 users were running on Mac OS, I am surprised I have not heard of this as a issue before.
I recommend that you post your Fusion 360 questions over here.....
Message 10 of 17
leej0nes
123D does it, don't know anything about the product beyond that and its in the App Store for free 🙂 Doesn't appear to report DXF or DWGs though.
Message 11 of 17
JDMather
I am pretty sure I have imported dwg and dxf too.
You might also check out Mesh Mixer
Message 12 of 17
leej0nes
Ha! I want to export. Depending on the pop's capabilities I might have to
use AutoCAD. I should just invest more time learning AutoCAD 3D. I'm
great with LT.
Message 13 of 17
JDMather
What is this "AutoCAD" you speak of?
How much experience do you have with *.stl files?
Message 14 of 17
How do you open STL files in Windows using this? I am not seeing all these file options you are, only a handful via "New design from File". Am only seeing STP files, not STL. Is there an "Open file" option anywhere?
Message 15 of 17
WHolzwarth
Try this:
- Switch to Fusion 360 and uncheck Work Offline option (if checked)
- Click on Icon shown in red circle
- Move STL file by mouse into upload window
Walter Holzwarth
Message 16 of 17
in reply to: WHolzwarth
tyvm
Message 17 of 17
JDMather
You should probably post your Fusion 360 questions over here.
