Inventor Forum
Import Inventor file (.idw) to autocad (model space)
10 REPLIES 10
Message 1 of 11
MechaDraftman
11205 Views, 10 Replies
How to import Inventor file 2D(.idw) to autocad 2D (model space) with dimensions, axes, sections, ... ?
Thanks.
Note: Inventor 2013 & Autocad Mechanical 2013
10 REPLIES 10
Message 2 of 11
ampster401
in reply to: MechaDraftman
does saving it as a AutoCAD dwg work?
Save As > Save Copy As > then choose "AutoCAD Drawings (*.dwg)"
HTH
Message 3 of 11
MechaDraftman
in reply to: ampster401
yes, I saved it as a autocad .dwg work.
When I open it with autocad I have a drawing in paper space and nothing in model space !
Moreover, it's "impossible" to make an adjustement in paper space.
It's easier with CATIA V5, just open your dwg in model space. Simple to make an adjustement and to allow a easy layouts.
Message 4 of 11
try reading through the options when you export
Message 5 of 11
MechaDraftman
Thank you for your advice but I can't find an option when I export or procedure to solve my problem.
Message 6 of 11
MechaDraftman
SOLVED !  thank you richos69
  1. Export
  2. Export to DWG
  3. Select Type "Autocad DWG file"  (default: INVENTOR DWG file !!! ) - printscreen "DWG export-A"
  4. Click on "Options"
  5. Select option, button "Next" - printscreen "DWG export-B"
  6. Select parameters, button "Finish" - printscreen "DWG export-C"
  7. Save your DWG file
  8. You can use it with autocad in model space
Message 7 of 11
thats it
...sorry if answer was a bit short, I would normaly try to put up a screenshot...it was at the end of a 10 hour day and I think I have a kidney infection...off to doctor this morning (Im in australia so time difference meant i missed your next post)
Message 8 of 11
cloyeswg
This doesn't actually answer the question or solve the problem of bringing in a .IDW file into AutoCAD.  This tells you an alternate way of doing this by avoiding the use of .IDW file format.
What happens if you do not have Inventor available to open and then re-export as a DWG format?
Message 9 of 11
Anyone have following installer?
AutoCAD_2024_English_Win_64bit_dlm\x64\IX\InventorServerInterop.msi
Message 10 of 11
Hi! Please log on to manage.autodesk.com and download the package.
Many thanks!
Software Test Engineer
Message 11 of 11
Thank you very much sir
