Hi InventorWizardz,
I have a problem with the folowing script:
Ivolume = iProperties.Volume/1000 '(in cm^3)GoExcel.CellValue("3rd Party:Embedding 2", "Blad1", "A2") = Ivolume
Parameter("HoogteVolumePercent") = 1
i = 1
If Parameter("HoogteVolumePercent") < 100 Then
While (Parameter("HoogteVolumePercent") < 100)
GoExcel.CellValue("3rd Party:Embedding 2", "Blad1", "C"&i) = Ivolume
i = i + 1
If i = 100 Then
Exit While
End If
End While
End If
iLogicVb.UpdateWhenDone = True
The purpose is to export the value of Ivolume at a certain percentage to an embedded Excel. But the when running this rule every cell has the same value.
I think Ilogic is writing the value after the completion of the rule. But I can't figue it out to get it to work.
In Attachements you can find a screenshot and the part.
Hope someone can help
Solved by andrewiv. Go to Solution.
I modified your code to include an update before writing the mass to the "C" column and to also tell it to change the HoogteVolumePercent parameter to be the i value. This works for me
Ivolume = iProperties.Volume/1000 '(in cm^3) GoExcel.CellValue("3rd Party:Embedding 2", "Blad1", "A2") = Ivolume i = 1 If Parameter("HoogteVolumePercent") < 100 Then While (Parameter("HoogteVolumePercent") < 100) Parameter("HoogteVolumePercent") = i InventorVb.DocumentUpdate() Ivolume = iProperties.Volume/1000 '(in cm^3) GoExcel.CellValue("3rd Party:Embedding 2", "Blad1", "C"&i) = Ivolume i = i + 1 If i = 100 Then Exit While End If End While End If iLogicVb.UpdateWhenDone = True
Andrew In’t Veld
Designer
