Inventor Forum
Ilogic Save drawing as inventor dwg
1 REPLY 1
gazadder
950 Views, 1 Reply
Is there a way in an inventor drawing rule to do a "save as" which saves the drawing as an Inventor dwg file rather than an AutoCAD dwg file?
The below saves as AutoCAD which is ok but I need the outputted drawing to be linked to the model.
I don't want the code to save the entire assembly as this is done further down the line.
I also don't want to save the current inventor dwg drawing from which the rule is run as this is just a template drawing.
ThisDoc.Document.SaveAs(ThisDoc.Path&"\2D_DRAWINGS\"&iProperties.Value("Custom", "Drawing No.")&" (Rev "&Parameter("BEAUFORT_ARRANGEMENT_3.iam.DRAWING_REVISION_NO")&")"&".DWG", True)
1 REPLY 1
gazadder
in reply to: gazadder
Format:HTML Format Version:1.0 StartHTML:     165 EndHTML:     614 StartFragment:     314 EndFragment:     582 StartSelection: 314 EndSelection:     314
SyntaxEditor Code Snippet
ThisDoc.Document.SaveAsInventorDWG(filename)
