Inventor Forum
Idw - Dxf conversion
15 REPLIES 15
Message 1 of 16
capmacindustry
2282 Views, 15 Replies
Hi There!
I have a problem... When i try to convert a simple file .idw to .dxf, using menu file - save copy with name, I receive an alarm message (this is an italian-english translation):
"program initialization failed conversion 2d"
And the file is not saved and converted! I have the problem with 3 pc. I also tried with other files, but the problem persists...
The great thing is that until two days ago it worked!!
Do you have any solutions?! Thanks!!
15 REPLIES 15
Message 2 of 16
Jazst
in reply to: capmacindustry
I have the same problem - it worked perfectly fine until a few days ago.
When saving ''inventor dwg'' or ''inventor idw'' drawing as ''autocad dwg'' or dxf drawing I get an error message: ''Failed to initialize 2d translator.''
When exporting sketch from part file to dwg or dxf i get an error: ''DWG/DXF export error.''
Any ideas how to get it to work?
Thank you.
Message 3 of 16
capmacindustry
in reply to: Jazst
Hi Jazst,
maybe do you use Avast antivirus? I think that the problem is it... After the last update...
Message 4 of 16
Jazst
yes, I have avast. I uninstalled it now, but the problem persists. You tried uninstalling it? Could the problem be with windows (update)?
Message 5 of 16
capmacindustry
in reply to: Jazst
I tried to unistall avast one hour ago, but the problem persist, me too... Do you think that the problem is an update of windows? I have win 7, 64bit machine.
Other possible solutions? Smiley Sad
Message 6 of 16
Jazst
I have win 7 64bit also and Inventor 2012.
Anyone else with the same problem?
Autodesk do you have any ideas?
Message 7 of 16
segri05
Identical problem.
win 7 64bit also and Inventor 2012, Avast antivirus.
Message 8 of 16
capmacindustry
in reply to: segri05
Ok, now we are 3 people with the same problem...
I'm more and more convinced that the problem is Avast. Maybe it has changed some parameters or configurations of Inventor (my version is 2011). Also uninstalling Avast, the situation doesn't change...
Now, i try to unistall and reinstall Autocad Inventor.
Message 9 of 16
BarryZA
4 people...
I tried to do a clean uninstall and now my optical drive dosen't seem to work either.
I need to get drawings through to the laser cutters tomorrow. Very bad timing.
Message 10 of 16
BarryZA
in reply to: BarryZA
Sorry, Can't seem to edit my previous post.
Fixed with the following:
Pulled out internet connection.
Ran system restore to the beginning of the month.
Uninstalled Avast (no internet so it couldn't update 🙂
Opened Inventor Save copy as - .Dxf, - Autocad.Dwg straight away.
Now to catch up my work from the last 2 days..
Message 11 of 16
swhite
not saying this is related, but you might check the Add-In manager to make sure its loaded.
Steven White
Lee C. Moore, Inc.
www.lcm-wci.com
Inventor 2011
Intel Dual Xeon E31225 @ 3.1 GHz CPU
16 GB RAM
NVIDIA Quadro 600 GPU
Windows 7 - 64 Bit
Message 12 of 16
BarryZA
in reply to: swhite
tried that as admin, but they kept unloading before we could save.
Message 13 of 16
swhite
I have that problem with my drawing tools, but at least I can force them to open as a toolbar, but checked, and can't do hat with translators. Sounds like Avast might of changed a registry entry and the translators may not be found now. You might try just reinstalling or repairing Inventor, see if that solves it before you do a complete system overhaul. Just make sure any antivirus is turned off when you do. Otherwise it's beyond me, sorry.
Steven White
Lee C. Moore, Inc.
www.lcm-wci.com
Inventor 2011
16 GB RAM
Windows 7 - 64 Bit
Message 14 of 16
Paul-Mason
in reply to: swhite
I've just done a IDW ~ DXF save as one one of my drawings no problems at all the normal dialog box popped up. Conversion went as normal. I do, however, have all translators load behavior set to automatic/on demand. In addition I DO NOT have Autocad installed so that rules out Acad being needed.
I would suggest that you try a repair install of inventor and see if this fixes the problem
Inventor 2023 Pro
HP Z420 workstation
Xeon 3.7Ghz CPU 8 Cores, 64 GB Ram
64bit (The Garbage known as) Windows 10 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
Message 15 of 16
Jazst
in reply to: Jazst
Thank you.
I waited a while to see if anyone has been able to solve the problem without system restore.
Unfortunatelly I waited too long and my system restore no longer restores my setting to when the translation worked.
I desperatelly need the translation now, please advice me what to do..
Thany you for your help.
Message 16 of 16
NielsMaas
in reply to: Jazst
Same problem here. Also on a system with Avast virussoftware.
Wndows system restore is not an option here. I was thinking, doesn't the Inventor setup repair do the trick?
Has anyone tried?
Greetings,
Niels
Windows 7 professional / SP1 / 64bit
Inventor 2012 professional SP2
