I work in two machines with windows XP and 7 and in both the icons for all types of files of Inventor are the same. How can I solve this without editing registry?
Thanks in advanced
Try here: http://www.vistax64.com/tutorials/178915-file-extension-type-icon-change.html
It's listed for Vista, but it should be the same for current Windows O/S
Thanks for sharing how to make changes in regedit but know I need the icons themselves... Does anyone can share them so I can put in my machine?
Your icons are going to appear the same no matter what operating system you are using. Not sure why you would want them different from OS to OS. Consistency, it's a beautiful thing.
My friend, this is the point of this post!... to get the normal icons of inventor in my OS because now part, assembly, presentation and drawing as all the same dam icon...
I've changed registry and both XP and 7 the icons appear as inventor normal icons, but inside inventor the icons still are all equal a square with the "I" of inventor... any suggestions...
I guess I misunderstood you the first time.
Have you tried manually changing the icon association from the 'File Type' tab in Windows Explorer's folder options (XP)? (I still haven't figured out how to change these in Win 7)
.iam uses: \Inventor\Bin\AmRes.Dll to get it's icon.
.ipt: Bin\PmRes.Dll
.idw Bin\DlRes.Dll
I've changed already the dll in XP and in the explorer its fine but inside inventor its a mess with all icons being the same... in 7 I've searched but still haven't found beside the dll that didn't work how to change the icons... (didn't know if i made myself undestand..)
Possible, one may need to repair Inventor to re-register the icons. Not sure what you have done to both your XP and Win7 systems to cause this issue.
Make sure you are logged in with Administrator privileges, all Anti-Virus is disable/turned off, in Win7 the UAC slider is off (slide to lowest setting).
OlĆ” Filipe
Why not try repair your Inventor installation????
Manuela
hi, didn't work, but uninstaled and instaled again in WIN 7 and it was fine until some days ago that turned again to same icons for diferent fyle type... it's a mess finding what you need when all as the same icon...
Hi, try next:
in XP you need to go to Folder Options,File TAB type, in Win 7 is different: Start, Default Programs, Associate a file type ..., so in new window find an extension (ex. iam) and reassociated with the program (ex. Inventor 2010). Do the same for all extensions and should be ok! That's all.
Some more infos for fun :
Icons for Inventor are defined in the registries :
[HKEY_CLASSES_ROOT\Inventor.DrawingDocument\DefaultIcon]
The same for Inventor.PartDocument, Inventor.AssemblyDocument
Value should be :
="C:\\Program Files\\Autodesk\\Inventor 2012\\Bin\\FwUIRes.dll,4" for drawings
="C:\\Program Files\\Autodesk\\Inventor 2012\\Bin\\FwUIRes.dll,0" for parts
="C:\\Program Files\\Autodesk\\Inventor 2012\\Bin\\FwUIRes.dll,1" for IAMs
This info is valid for 2012. I did not checked for 2010
