Does Inventor render sketch graphics with the CPU only and not use the graphics card?
I've noticed that when I have a few moderately complex sketches in a part file (eg. for skeletal or multi-body models), Inventor stutters and lag when I rotate, pan, and zoom after I reach a certain complexity. It's almost as if Inventor is not using the graphics card at all for sketch geometry but is trying to run it all off of the CPU.
If I continue working in the file and create a multi-body model with solids, textures and everything from those sketches, I notice that I can turn off the sketch visibility and rotate the model with all of its solid bodies, textures, etc. quite smoothly. Yet, as soon as the sketch visibility is turned on the model stutters and lags on rotation. In fact it almost seems that Inventor can rotate the textured solid bodies more easily than it can rotate the sketches they were created from.
To take this a little further, I can put my multi-body model into wireframe view (which should require that far more lines be rendered than with when the sketches are visible) and it rotates beautifully. As soon as I turn on the skeletal sketches it lags.
This seems counterintuitive. Shouldn't it be more demanding to rotate all of the textured solid bodies or all of the wireframe lines than a set of sketches. I'm wondering if Inventor is using the graphics card for rendering solid models but not sketch geometry. Is that so? Or is there another explanation for this?
Steve
HP Elitebook 8740W
Intel Quad Core i7 Q740 (1.73GHz)
12 GB RAM
NVIDIA Quadro FX 3800M
SSD Hard Drive
Windows 7 64
I'm just giving this a bump to see if anyone knows the answer to this question now since I continue to experience frustrating performance in the sketch environment when creating moderately complex layout sketches.
Steve
