It's a bug, it becomes really obvious if you add text to your dimension
string. It is especially obvious when you use dual dimensions (as I do),
but it seems the effect is proportional to the amount of spaces in the
dimension string.
If you have a dimension that contains vertical text and you try to drag it
horizontal, the effect is really pronounced, since you can't drag it even
close to where it would be in R10. Often dimensions will go right off the
sheet, with no way to bring them back.
http://discussion.autodesk.com/thread.jspa?messageID=5221035
http://discussion.autodesk.com/thread.jspa?messageID=5340339
It appears to be logged as issue 801400, but it is taking waaaaay to long to
address this. It is another example of something that suddenly became
busted in R11.
I can only hope that SP3 is on the way.
Gary
wrote in message news:5380575@discussion.autodesk.com...
Please take a look at the attached picture. Why does IV11 SP2 put the
dimension value so far away from the arrows when the value is place outside
of the arrows? It did not do this in IV10 SP3a
