Excuse my lack of double checking my grammar and spelling as Mod was
intended to be Mold. {;^/ I also find the same conflict you do in that I
must work with ProE to satisfy my customers and find that at times my habits
from MDT getting in the way. You said it best when you said "Open Mind". I
think that there are a lot of people in the "CAD World" that have closed
their minds and . . . as I am sure you have seen plenty of . . . have
disgraced what we all love to do, which is create and design, by polarizing
to one format or another rather than trying to understand the power of many
and how they can be used to their advantage. For example, I use MDT as my
primary but find limits each day. I can export and import to Pro and
sometimes accomplish the feature I couldn't in MDT. Sure, I get a base part
when I import back to MDT, but I ultimately get what I need . . . I'm
successful in design even if it ends up being more work. Now don't get me
wrong, I find a fair number of limitation in Pro as well and that is why MDT
is still my platform of choice.
Thanks much for you candor and lets all hope that all systems continue to
improve and challenge each other for that is what makes them all better. I
only hope that we all can be constructive in other criticism and ultimately
have an "OPEN MIND"!!
Thanks Kent [B^)-
Mark N
"Kent Keller" wrote in message
news:B27F65E8AAE4FE5423F00F42CD70A8B8@in.WebX.maYIadrTaRb...
> Mark
> Keep in mind I do basic mostly right angle sheetmetal work. Molds,
> surfaces etc are all Greek to me I am not sure what you mean by mod
> design (is my ignorance showing yet)
> I don't see any reason it wouldn't be a good package for those types
of
> things though. I am sure there is probably quite a few people doing both
> here, and hopefully they will chime in with opinions.
> The hardest part about Inventor for me is un-learning MDT, and I still
> struggle with that at times. I think at times Inventor tends to take too
> much computing power also. The graphics is great when it works, but it is
> extremely touchy and important.
> I think you will find Inventor very capable in the areas you are talking
> about, but you will have to have a open mind and accept things aren't
going
> to be done the same as they were in MDT.
> Sorry, can't be more help, just not enough experience in the areas you are
> working in.
> Kent Keller
> Member of the Autodesk Discussion Forum Moderator Program
> http://www.MyMcad.com/KWiK/Mcad.htm
> "mn" wrote in message
> > Will IV6 work well for mod design as well as part design?
> > Do you see any drawbacks in using this as a true mechanical engineering
> > package for the manufacturing sector. i.e.: plastic injection molding
and
> > metal stamping?
