Inventor Forum
IV Dynamic Sim. has Locked Assy even if it moves freely in Assy Environment
5 REPLIES 5
RobHarker
487 Views, 5 Replies
I'm able to move the contrained parts in this simple assy but when I move to either the dynamic simulation or the inventor studio I'm not able to move any parts.  They are locked up.
 Edited by Request
Discussion_Admin
5 REPLIES 5
ravikmb5
in reply to: RobHarker
Post ur model if possible
only by screen shot it is difficult to explain
Please mark this response as Problem Solved if it answers your question.
Ravi Kumar MB,
i7 860 Dell Studio XPS Win 7 64 bit 12 Gb RAM & HP Z220 SFF Workstation
Autodesk Inventor Certified professional 2016
Email: ravikmb5@gmail.com
JDMather
Have you gone through the tutorials?
In Studio environment - you must animate the constraints (you have not provided screen capture of Animation Timeline).
In Dynamic Simulation environment you must have proper motion Joints defined such the the moving bodies are not grounded (you have not provided screen capture of the Joints).
Both of these topics are covered in the Tutorials.
RobHarker
in reply to: JDMather
I did the tutorials a while ago and do remember that it warned that an over-contrained assy can cause issues when automatically generating dynamic simulation joints from contraints.  In the FAQ it suggests suppressing contraints and then moving to the DS environment to see which contrstaint is causing the problems.  I'll review the tutes and try this.
DS does warn me that I have 5 degrees of redundancy
Thanks all.
ravikmb5
Dynamic Simulation works exactly as it should
Designers who used DMU kinematics in Catia will be definetly understand the behaviour of Dynamic simulation environment
we need to suppress some constraints before switchng to DS environment
Ravi Kumar MB,
RobHarker
Thanks ... that's a lot of help.  It was explained in the tute that concentric contraints are frozen as if welded because most concentric contraints are for bolts and screws.  Having deleted all the concentric contraints and replacing them all with mates along axes unfroze my model and now I just have to figure some parameters and add my forces.
