Inventor Forum
IV 2013 Factory Design Suite- Appearance adjustment/change in Weldment
3 REPLIES 3
3DAli
422 Views, 3 Replies
Hi
I was wondering if there is a way to change the appearance of a face in a weldment assembly environment. I have a weldment which in the machining process a part of weld bead as well as a portion of one of the componets is machined down (spot faced) and I need to change the apprearance of those face to polished, but it doesnt let me do that? is it me, or its not possible?
Signature_Small
3 REPLIES 3
blair
in reply to: 3DAli
Currently all the welds beads will change.  Select the weld bead (any weld bead) and then change the appearance from the Appearance drop-down menu and unfortunately all the weld beads in the assembly will change. Short of Photo-Shopping a picture I don't think it can be done
Delta Tau Chi ΔΤΧ
3DAli
in reply to: blair
yeah, I thought so, cause I tried different ways and unfortunately I couldnt, if it was in a part environment, it was easy as you can change the appearance of any operation generated face through properties in the right click menu.
maybe a good one to add to wish list for future versions.
Thank you
Ali
Signature_Small
SBix26
in reply to: 3DAli
Inventor IdeaStation is the place to do that.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
