Auto-miter works great if you select a face loop. In your case, you have
selected two adjacent edges and (while not intuitive) what you will need to
do will be create a corner seam. For help on how to do this, type in "sheet
metal" on the Index page of the help system and the very first entry is
called: 3 bend corner
Select that and you should see a topic entitled: Add corner seams to sheet
metal faces
Towards the bottom of that page (under the note) there is blue arrow next to
text that reads: Three-bend corners
Select that and you should see the exact case you are trying to create.
All that said - I agree that your method should work and making that
workflow behave as you expect remains on our list of things to do.
Gary R. Smith
Autodesk Inventor Team
Portland, OR
2.33GHz 2GB IBM ThinkPad T60p; XP pro SP2
ATI Mobility FireGL V5250 driver: 8.293.1.0
