Inventor Forum
INV 2015 BOM sort by Item No. Issue
3 REPLIES 3
IvanoSimonetto4519
565 Views, 3 Replies
In previous Inventor versions (2014 and before) when sorting BOMs by item number it would sort correctly. Ie, 30 items 1 to 30.
However when sorting BOMs by item number in 2015 it is incorrect. Ie, 30 items read 1,10,11,12.... 19, 2, 21.... 29, 3, 4, 5, etc. This is very inconvienient when trying to change numbers then re-order to suit drawings.
The only way around this and have items sort correctly is to make items 1-9 read as '01-09' which I don't want to do.
Does anyone know how to fix this problem? Or is this a problem which Autodesk are intending to hotfix?
Cheers
3 REPLIES 3
Though i never sort by item number, i gave it a quick try to see what happens.
I'm sorry to say that i can't confirm this, for me it sorts like expected.
I don't know what is causing this for you.
Do you have 2014 installed on the same system?
Does it sort properly?
Did you install update1 for 2015? (there's no mention of sorting problems in the readme though...)
It might even be some windows setting, i wouldn't be surprised...
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Hi IvanoSimonetto4519,
you are correct. This is an unintended change in 2015.
Our quality assurance is already aware of this and this behavior is currently in backlog for our development.
But there is a simple workaround:
The sort order is not correct when sorting by cklicking column header.
If you use "Sort Items" you can sort by "Item". Then you can see that the sort order is correct.
Hope this information is helpful.
Dennis Ossadnik
Senior Technical Support Specialist
Still the same with 2015 SP1. Now even worse, because totally broken in English version, but works like in Dennis' hint in German version.
I'll try again.
Later: Seems refusing for a new sort by item, but is coming back to short life after another sorting criterium.
I don't like that behavior.
Walter
Walter Holzwarth
