Inventor General Discussion
Active Member
mceitrs
Message 1 of 3 (707 Views)
ILogic rule for ipt browser node renaming?
707 Views, 2 Replies
10-18-2011 06:13 AM
Hi all,
is it possible to rename the browser node on part level with an iLogic rule? I know that in the assembly environment is an Inventor OOTB functionality to rename the nodes to the filename, Part number or the default value.
Any help would be appreciated.
Raphael
Inventor Professional 2011
Windows 7 Enterprise 64bit
Dell Precision M4500
Intel(R) Core(TM) i7 CPU Q 820 @ 1.73GHz
8 GB RAM
Product Support
jon.dean
Message 2 of 3 (659 Views)
Re: ILogic rule for ipt browser node renaming?
10-21-2011 03:48 AM in reply to: mceitrs
Take a look at the following website, I think it will answer your question:
http://ellipsis-autodesk.typepad.com/blog/2010/06/new-ilogic-web-series.html
If you need more help then let me know.
Jon
Jon Dean
Active Member
mceitrs
Message 3 of 3 (563 Views)
04-10-2012 10:05 PM in reply to: jon.dean
Hi Jon,
thanks for your help. I found the soulution here:
http://forums.autodesk.com/t5/Autodesk-Inventor/Inv-2011-How-do-I-set-quot-Part-Number-quot-as-the-d...
This is exactly what I was looking for.
I am now using an iLogic rule to compose the part number in the ipt file (it is a comination of a special item name and various part dimensions, and then the "UpdateAssyBrowser" rule is updating the browser names in assembly environment. Works great.
Bye
Raphael
8 GB RAM
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
