Hi all,
is it possible to rename the browser node on part level with an iLogic rule? I know that in the assembly environment is an Inventor OOTB functionality to rename the nodes to the filename, Part number or the default value.
Any help would be appreciated.
Raphael
Take a look at the following website, I think it will answer your question:
http://ellipsis-autodesk.typepad.com/blog/2010/06/new-ilogic-web-series.html
If you need more help then let me know.
Jon
Hi Jon,
thanks for your help. I found the soulution here:
http://forums.autodesk.com/t5/Autodesk-Inventor/Inv-2011-How-do-I-set-quot-Part-Number-quot-as-the-d...
This is exactly what I was looking for.
I am now using an iLogic rule to compose the part number in the ipt file (it is a comination of a special item name and various part dimensions, and then the "UpdateAssyBrowser" rule is updating the browser names in assembly environment. Works great.
Bye
Raphael
