Inventor General Discussion
mrattray
Message 21 of 33 (526 Views)
Re: iLogic set BOM via Visibility
10-24-2012 12:26 PM in reply to: d_m_fleming
Oops, my falut. I'm not good at multi-tasking! :smileyembarrassed: Find it attached to this post.
By data set I mean your assembly and it's accompanying parts.
Mike (not Matt) Rattray
d_m_fleming
Message 22 of 33 (520 Views)
10-24-2012 12:37 PM in reply to: mrattray
I'm working for a tank manufacturing company.
The data set is not something I can just post and I suspect is too large anyway.
This is a large assembly with many parts.
I created LOD's which I now know will not produce the BOM's I require.
I created view reps from the LOD's and am trying to get ilogic to give me a BOM that reflects only the parts in the View rep.
The code you sent is giving the same error but in lines 13 and 16 now.
mrattray
Message 23 of 33 (495 Views)
10-25-2012 05:06 AM in reply to: d_m_fleming
Tanks as in military tanks? If that's the case, I imagine mentioning as much as you have could get you in trouble! :smileytongue:
I have two theories as to why your having problems. Try this version, and if it doesn't work then we'll test theory two.
Active Member
mohan.nakka
Message 24 of 33 (441 Views)
12-11-2012 02:51 PM in reply to: mrattray
hi,
 anyone tried the code ?still have the same error messages in line 16 and 19
Active Member
mohan.nakka
Message 25 of 33 (441 Views)
12-11-2012 02:52 PM in reply to: mrattray
hi code doesnt work,please help
Curtis_Waguespack
Message 26 of 33 (430 Views)
12-11-2012 03:12 PM in reply to: mohan.nakka
Hi mohan.nakka,
There seems to be some mystery characters as shown.
If you retype the word BOMStructure in both places shown it should take care of it.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Active Member
mohan.nakka
Message 27 of 33 (420 Views)
12-11-2012 03:27 PM in reply to: Curtis_Waguespack
Thanks Curtis,
      That cleares the error message.I added this rule to an assembly file which has a view rep i created.i added this rule to fire with an event trigger "after save document".but none of the invisible components BOM structure is change to reference.Am i doing it right?Please help.
Thanks a lot
Mohan
Active Member
mohan.nakka
Message 28 of 33 (419 Views)
12-11-2012 03:42 PM in reply to: mohan.nakka
hi curtis,
          i created a sample assembly with few parts and tried the code,it works great.where should i use this code if i have sub assemblies in a top level assembly?
Distinguished Contributor
Infoseeker
Message 29 of 33 (400 Views)
12-12-2012 07:15 AM in reply to: mrattray
I treid this rule and unfortunately does not work for me, I suspect the reason is complicated BOM set up I use.
Other guys did not complain.
Active Contributor
LewisLusby
Message 30 of 33 (315 Views)
04-23-2013 08:17 PM in reply to: Infoseeker
Why does this only work in Master LoD???
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
