Inventor General Discussion
Valued Contributor
chrisw01a
Message 1 of 7 (820 Views)
IGES Import problems convert to solid part
820 Views, 6 Replies
07-19-2012 07:41 AM
Could somebody PLEASE take a look at these two IGES parts and try to convert them to a solid.  I've tried all I can think of with no good result.
I can't get them uploaded, file is too large, what can I do?
Valued Contributor
chrisw01a
Message 2 of 7 (814 Views)
Re: IGES Import problems convert to solid part
07-19-2012 08:32 AM in reply to: chrisw01a
These are actually .rar files.  You will have to change the extention to .rar and use WinRar to extract.
JDMather
Message 3 of 7 (801 Views)
07-19-2012 09:26 AM in reply to: chrisw01a
Why are they *.rar files?
Why can't you simply use Windows Explorer to zip the files?
The limit is much larger over here http://www.augi.com
I have no interest in downloading a 3rd party software to extract your files, but perhaps this will help you
http://home.pct.edu/~jmather/AU2008/ML205-1P%20Mather.pdf
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Valued Contributor
chrisw01a
Message 4 of 7 (796 Views)
07-19-2012 09:29 AM in reply to: JDMather
Because .rar could get small enought to upload.  I'll look at the other website.  Thanks.
JDMather
Message 5 of 7 (793 Views)
07-19-2012 09:31 AM in reply to: chrisw01a
Put a link back here to the upload on AUGI as that site doesn't get  as much traffic.
I've got to get back to other work for a while, so hopefully someone will jump in here with solution.
Back to check in a while.
Valued Contributor
chrisw01a
Message 6 of 7 (788 Views)
07-19-2012 09:45 AM in reply to: JDMather
JDMather
Message 7 of 7 (775 Views)
07-19-2012 12:47 PM in reply to: chrisw01a
Those look pretty easy to repair - should be able to fix each in a couple of hours using the instructions I referenced earlier (with a bit of changes accounting for the Repair Environment changes from Construction Environment).
There are some missing surfaces that need patched.
But why do you need as solids?  These look like off-the-shelf Motors.  If you aren't manufacturing - why do you need solids?
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
