Inventor Forum
IDW view does not show changes-Bug?
3 REPLIES 3
128 Views, 3 Replies
I revised a part in a 30+ part IAM file (made part longer) but the IDW will
not reflect the change in all views for the assembly or parts views.
Some views updated fine related to the change, others do not show any change
& the views of the part itself shows the dimension correct but the length is
very obviously wrong . ( see screen shot example in CF )
I was able to create a new projected view off of the offending view that was
accurate, however.
Is there a setting I am missing or is this a bug?
Tools/Docment Settings/Drawing Defer Updates is unchecked.
I opened & saved all subassemblies (eVen though I shouldn't have to)
I have multiple sheets in IDW file & similar views on sheets sheets are
incorrect.
Sys Specs
IV6 Sp1
Win2K (latest Sp)
Dual Athlon 2200 MP
1Gig ram
Quadro 4 750 XGL
3 REPLIES 3
I have had this same problem. I have gone into IDW files where a part has
been updated, the dimensions will have updated correctly but the object
lines have not. For example I had a part where a hole had been moved and was
dimensioned from part edge to hole center. When looking at the IDW the
dimension was dimensioned from part edge to nothing but was correct; the
hole had not moved. I found that if I went into the assembly rebuilt and
updated then returned to the drawing, the drawing corrected itself.
Note that these were migrated files from 5.3 and before sp1. I have not seen
this since. I had to plot a 200 sheets and check to make sure that the
dimensions went to something then fix those dimensions that seemed
unattached.
Al Jolley
ACJ Enterprises, Inc.
"Gary Cross" wrote in message
news:6A2BCBD4A2184FF87B43531CE3EE4F07@in.WebX.maYIadrTaRb...
will
change
is
was
> accurate, however.
> incorrect.
> Sys Specs
> IV6 Sp1
> Win2K (latest Sp)
> Dual Athlon 2200 MP
> 1Gig ram
> Quadro 4 750 XGL
A little bit difficult to debug without actually having the files but one
suggestion though:
did you try to select the out-of-date views (with left mouse button) and use
the Update icon ?
This is a yellow lightning icon that gets enabled in the Inventor Standard
toolbar only when at least one view is selected.
Bob
Inventor workflow QA
I was not aware of it but was looking for it when I was having the problem.
I will try it next time this comes up since I redid all the offending views
due to lack of time (& knowledge).
Thanks Bob!
Gary
gcross@crossdesign.com
"Bob Van der Donck" wrote in message
news:1803BADBFBFF91792FC17D7D9F23A27B@in.WebX.maYIadrTaRb...
> suggestion though:
use
> the Update icon ?
> Bob
