Inventor Forum
*.IDW template file
6 REPLIES 6
jyothissurendran
993 Views, 6 Replies
*.IDW template file
Hi
I have a drawing(*.idw) file that already made from a template file. Now i have created a new template file. So any option available to use new template file for the existing drawing file with old template. Much appreciated if somebody can advise....
Jyothis Surendran
Autodesk Autocad 2014 & Inventor Professional Suite 2010
Windows 10
6 REPLIES 6
Cadmanto
in reply to: jyothissurendran
Jyothis,
Having both your updated tempate file and the old one open, in the new template file, in the browser under "Drawing Resources", RC on the sheet format (have to do same operation for the titleblock as well) and select copy.
Then in the old drawing in the same location (under "Drawing Resources") select "Paste" .  It will prompt you asking of you want to replace the olde one.  Just say "Yes.
Hope this helps.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
jyothissurendran
in reply to: Cadmanto
Thanks scott. it works fine....Smiley Happy
Jyothis Surendran
Windows 10
Cadmanto
You're welcome.
Best Regards,
Scott McFadden
Fori123
Scott,
I have a quick question on idws that I would like to ask you. We only use 4 specific sheet sizes at the company I work for. Can we remove the 10-15 other sheet sizes we do not use and will never use? See attached image.
Thank you,
Mike
You can also use the Drawing Resource Transfer Wizard to copy this new title block into a entire set of drawings instead of individual copy and paste.  This is a very common tool for companies that change their address or want that TB to back date a little bit.
You'll find this tool in your Start Menu.
http://blogs.rand.com/manufacturing/2011/08/all-my-inventor-drawings-need-a-different-title-block-ar...
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
mflayler2
in reply to: Fori123
No, those sizes are there to stay.  What you might consider is an iLogic Form that fills out your TB as well as chooses Sheet Size from a predefined smaller list when you work in your drawing.
