Inventor Forum
IDW file format update to all my old idw files
7 REPLIES 7
Message 1 of 8
AhmetSevik
871 Views, 7 Replies
I am user for Inventor 2013 Professional.
1 year ago i created a format for my idw template file. I set many things under Drawing Resources in browser.Sheet Formats, Borders, Title Blocs, Sketch Symbols... etc. Now we want to change something in this resources and i will create new one.
My question is if i create new one, then can i update all new formats to my old idw files? I mean, i can't open all of old files and i can't change one by one. I want to do in easy way.
Thanks.
Ahmet ŞEVİK
7 REPLIES 7
Message 2 of 8
in reply to: AhmetSevik
i think there's a way to save your old files to 2013.
Message 3 of 8
blair
Have you looked at the: "Drawing Resource Transfer Wizard" that is shipped and installed with Inventor. It's located within the Inventor>Toold of the Start Menu
Delta Tau Chi ΔΤΧ
Message 4 of 8
blair
Here's a good link: http://blogs.rand.com/manufacturing/2011/08/all-my-inventor-drawings-need-a-different-title-block-ar...
Delta Tau Chi ΔΤΧ
Message 5 of 8
AhmetSevik
I solved my problem with Drawing Resource Transfer Wizard. I did'nt see till now this wizard under start menu.
Just one point; if your files saved with different inventor version then this wizard couldn't succes to convert. Then you should to open your old file with your inventor and you have to save again with new version. Then Wizard work.
Thank you very much to all of your helps. Thanks.
Message 6 of 8
SBix26
If your files need to be migrated, use the Task Scheduler, also in the Start menu.  You can set up a Migrate task for a project or folder, or select individual files.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
Message 7 of 8
blair
If you have any custom material/appearances, migrate them first. Good documents on the Autodesk website. I follow the following procedure when migrating.
1.) Have a good copy of your data. We have all data stored to a external USB drive. This is much easier to recover than having to restore from a Back-Up.
2.) Run the Task Scheduler and migrate all IPT's first
3.) Run the Task Scheduler and migrate all IAM's next
4.) Run the Task Scheduler and migrate all IPN's third
5.) Run the Task Scheduler and migrate all IDW's last
Delta Tau Chi ΔΤΧ
Message 8 of 8
SBix26
in reply to: blair
Blair, good point about the material/appearance migration.
As for the file migration, my experience with Task Scheduler is that it performs the migrations in the proper order, so you don't have to do it four times.
Sam B
