Inventor Forum
IDW Balloon Formatting - Want to number the Qtys in the Balloons - Properties
7 REPLIES 7
Message 1 of 8
1400 Views, 7 Replies
I have populted the Parts List for the small assembly that I have.  I need to label each part with an Item and Qty.  But I need the qtys listed as each number.  (i.e. - if Item number 8 has qty. 2 I need one ballon to be 8/1 and the other to be 8/2.  (see attached jpg (What I Want Qty.jpg).  I have gone into the Edit Ballon Style and changed it to the Circular - 2 Entries so I can have the Item number on the top and the qty on the bottom.  But I have tried every single Qty in the Available Properties and none of them will do what I need.  Please see attached for the various ones I have tried.  (It will only let me attach 3 files). The one called "Base Qty.jpg" is what happens with both Base Qty. as well as Unit Qty.  The one labeled "Item Qty.jpg" is what happens when I use both Item Qty. as well as Qty.  None of the choices available do what I need which is labeled as "What I Want Qty.jpg".  Does anyone know of a setting that I may be missing or an add-in to do this?  Our customer is the one requiring it.  We can put these in manually with a sketched symbol but then the balloons will not be linked to the Parts List.  I did search all thru these forum for almost 2 hours before posting this. I am using 2014 Inventor Proffesional.
Thanks!
Veronica
7 REPLIES 7
Message 2 of 8
mcgyvr
no possible "automatically" that I know..
Its kind of a silly customer request IMO.. Not sure of the point besides just additional busy work..
Maybe possible with ilogic code but I don't know..
Message 3 of 8
I feel for you, however this is whack. In the event there are many parts involved these quantities would do you no good whatsoever. I mean, they basically want the balloons to go through and count themselves off like "Hi, I'm number 3!"
Message 4 of 8
harco
I posted something a while back that may give you what you want but as mcgyvr points out it's definitely not automatic. It's a workaround and a bit of a pig too, I haven't even tried it since I posted but it did work back then. see this link http://forums.autodesk.com/t5/Inventor-General/Balloon-quanity-question/td-p/2590146 The second page has a bit of emphasis on the method where it's possible to go wrong. Other folk posted some easier methods in that thread also. Hope this helps a bit. Customers eh! wouldn't we get on a lot better without them!
Message 5 of 8
4donwan4
This is not possible with out of box install as others have commented on this. You can submit this request here to be considered for future release, http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
or post it to the ideas station.
Don
Message 6 of 8
in reply to: 4donwan4
Thanks Don.  I sent it in for a suggestion.
Message 7 of 8
mcgyvr
Veronica,
Whats the intent of this functionality?
or what benefit does it provide your customer?
I just can't see any point in that functionality at all other than maybe the order in which those parts are installed? Thats the only thing I can think of...
Message 8 of 8
in reply to: mcgyvr
We make separate spool drawings for each section so we label each item with its own qty number 1, 2, 3 etc.  We also use the same spool drawing to make our weld map and you have to have different identifiers.  If you have 3 flanges that are all Item 8 and the weld map has 3 different welds for all 3 we have to let them know which goes to which.
